496,451 active members
9,026 visitors online
Login Register
NC Service Blog
The overhauling process of a CORREA A16 milling machine is completed at NC Service
May 2018
15
Author: NC Service
Company: Nicolás Correa Service, S.A.
This bed type CORREA A16 milling machine was manufactured in 1989 featuring a Fagor 8020. This CNC has become obsolete nowadays, so NC Service decided to install an up-to-date Heidenhain TNC-320 CNC, including also a new control panel and a new HR-510 electronic handwheel. This full overhauling process and technology upgrade of this milling machine remarkably enhances its original features. NC Service guarantees its accurate machining after being modernized.
Among other jobs, our technicians carried out the replacement of bearings and ball screws preload in all three axes, while the working table, ram and framework were grinded and the guidance system was manually adjusted by means of scrapers in every axis. The milling head was fully inspected, grinding its main shaft and replacing its bearings and gears. A renewal of the electrical cabinet, building a new electrical panel with new control and power elements, as well as a new guarding kit also took place. Finally, the geometry and accuracy protocols were carried out as established by the manufacturer, certifying its right performance.
In the video you could watch part of this process and its final state.
Blog Archiv
January 2019
December 2018
November 2018
October 2018
September 2018
August 2018
July 2018
June 2018
May 2018
April 2018
March 2018
February 2018
January 2018
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
February 2017
January 2017
January 1970
