508,437 active members
3,590 visitors online
Login Register
Nicolás Correa Service, S.A. Blog
The three main movements about how a lathe works - Nicolás Correa Service
June 2019
26
Author: Nicolás Correa Service Team
Company: Nicolás Correa Service, S.A.
Turning is probably the first machining operation that resulted in a machine tool, the lathe, which main movement is the rotation one. This allows the machine to mould and shape solid parts such as cylinders, cones and propellers, and it is also used for smoothing, for making slots in parts, for cutting or sanding.
The operation of the lathe is very easy, as the piece to be mechanized turns on its own shaft carrying out a rotary movement, commonly known as a Working Movement, being the cutting tool the one that moves to the piece. Therefore, there are three basic movements:
  • Rotation movement: The part to be mechanized is placed on a rotating shaft, making it rotates around itself.
  • Advanced movement: The tool moves parallel to the piece, making a straight movement that defines the machining contour.
  • Penetration movement: The tool cuts part of the piece when penetrating in it, and determines the depth of the cut.
In our stock of machine-tools you will also find CNC lathes.
Blog Archiv
November 2019
October 2019
September 2019
August 2019
July 2019
June 2019
May 2019
April 2019
March 2019
February 2019
January 2019
December 2018
November 2018
October 2018
September 2018
August 2018
July 2018
June 2018
May 2018
April 2018
March 2018
February 2018
January 2018
December 2017
November 2017
October 2017
September 2017
August 2017
July 2017
June 2017
May 2017
April 2017
March 2017
February 2017
January 2017
January 1970
