532,226 active members*
2,582 visitors online*
Login Register
SAMAG News
High-performance machining centers from SAMAG – unprecedented speed, efficiency and power
Fast, faster, MFZ 4-2W
The MFZ 4-2W is part of the MFZ family of modular machines with two, three and four spindles for horizontal complete machining of cube-shaped parts made of steel, cast iron or aluminum. With its travel and feed range, it is currently the fastest machine of this type – in all three main axes. The result is an extremely powerful and highly productive machining solution for medium to large series production. Optimal piece costs are guaranteed.
Supplemented by optional rotary axes with direct drive technology (depending on the type) the MFZ 4-2W is equipped with two independent ZAxis spindle units with a clearance of 450 mm for five-sided or five-axis simultaneous machining.
TFZ 2L-1000 – two-in-one for more efficiency
With the deep drilling milling center TFZ 2L-1000 SAMAG offers its customers a machine that combines two technologies for the efficient machining of complex cube-shaped parts. The machine is designed for the four-sided complete machining of parts with a weight of up to 10 tons in one clamping. The combination of deep drilling and milling, together with a fast tool changing system, eliminates stack-up errors and costly set-up times. At the same time, the chip-to-chip times are also optimized.
The construction and extremely high rigidity of the machining center provide for maximum milling precision.
In addition, due to the energy efficiency inherent in the machine further cost savings can be realized. This is due to the “eco power” concept, which combines intelligent energy management, spindle drives featuring high efficiency and braking energy recovery as well as eco-friendly cooling solutions for the auxiliary systems.
Like all highly dynamic SAMAG machining centers, the MFZ 4-2 W and TFZ 2L-1000 can be adapted to individual customer requirements.
Visit SAMAG from the 5th until the 10th of October 2015 in Hall 11, Stand G18 at EMO in Milan and experience the MFZ 4-2W and the TFZ 2L-1000 live!
Responsible for the content of this press release: SAMAG Saalfelder Werkzeugmaschinen GmbH
Contact
Hüttenstraße 21
07318 Saalfeld
Germany
+49 3671 585-0
+49 3671 585-402
Route planner
Route planner
