Hi tintin,
I have all the installation disks, FW13.02. Please send me your email trough pm and I share you the dropbox link.
Where today meets tomorrow.
Hi tintin,
Hello.
Have you managed to repair your Agie machine?
regards
Does anybody has the image of the agiecut 250FS?
Thanks to your indications I have restored a CUT220, now I just have to set the correct language,
I have seen that in C: \ CU91 \ CU91MES.MES there is the language of the buttons, labels and messages,
there are 5 languages:
ENGLISH
DEUTSCH
RUSSIAN
FRANCAIS
ITALIAN
how do you set the language?
thank you very much
Hi, turbina,
that's an easy one. If the machine starts normally, at the very first screen that appears, just press "Esc" key. Then it will direct you to a "Main menu" screen, where, if I remember properly, F1 key is "Configuration pages". There is the option to change the language.
Regards
Done, thanks for your quick help !!!
Does anyone have a disc image for Agie Sprint 20? My hard drive died and we have no image backups of it. Trying to replace the hard drive but have no O.S. to copy over. Please help!
Hi Ironman.Anzus,
Could you please share with me your installation disks for FW13.02 ?
Thank you for the in depth instructions. The problem I am having is connecting an external ps2 keyboard to the agie 120 edm, so I can save the changed bios setting. the bios shows F10 to save it. The keyboard on the CF does not have an F10, so I will have to the ps2 keyboard. I plugged the ps2 keyboard into the board in side the cabinet and rebooted but the machine did not see it. I am stuck, any help will be greatly appreciated.
Thank you
is the keyboard powered on boot? check jumpers on the mainboard.
Thanks for the quick response. The keyboard light come on for a second and then off when I first boot up. I only have a operator not a service manual so I do not know which jumper on the board to check. I will send 2 pictures on the board with the ps2 connection. If you know which jumpers to change please let me know.
Thank You
oh, that's Siemens industrial computer. Congratulations ! - general knowledge of motherbords is useless.
On the other hand, there is high probability to find good data sheet by model name.
On the third hand, a regular PS2 keyboard could be incompatible.
On the last hand, all necessary setting combinations could be achieved via jumpers at that jumper field.
Yes I tried doing a search on the internet for KSP-M45-R66 and all that came up was the board selling on e-bay. I will continue searching on the internet again hoping for the best. If you happen to come across the data sheet or find that the ps2 keyboard is not compatible, please let me know. If anyone else has any other ideas i would appreciate knowing.
Thanks again for the quick response and ideas to check out!
check if there is "tab" on that keyboardThe keyboard on the CF does not have an F10
manys systems support cycling through options with "tab" key.
I tried using the TAB key when booting and in the bios but unfortunately it did not work. Thanks for the idea, it is appreciated. I am willing to try any ideas anyone has.
Thanks You Again
Hello, I would like to know at what point I need the "Final config" disk. yks said that this disk is a must for rebuilding a drive, but I can't find any indication in his manual at what point the "Final config" disk is needed. Maybe the master himself can tell you or someone else?
Thank You
Thank You very much, yks!
Good day.
Thank you for taking the time to read this.
We have an AGIE 250Hss that no longer takes axis reference
(axis do not move at all) point and gives the following errors:
No connection to host.
Check, if computers are powered and connected.
In the red field it writes L_ and in the grey field next to that Line down.
Additionally the motor where the wire spool sits keeps spinning counter clockwise when it should not.
We have a donor machine and have replaced everything in the CF control cabinet (entire backplate with all pcbs inserted) and also the WID4 board on the machine itself.
The HDD was also changed with the one from the donor machine.
After changing everything :
The motor where the wire spool sits keeps spinning counter clockwise when it should not.
The machine axis do not move.
No connection to host.+ Check, if computers are powered and connected. errors disappear
With this donor HDD the machine also has problems booting.
It gets stuck on autoexec.bat 9 out of 10 times. (on the 10th it boots)
We came to the conclusion possibly both HDDs are bad/partially corrupted.
We put everything back to the original state. (we put back the backplate together with the original HDD)
Would copying the original final config disk (we have it) help?
If so how can we do it without reinstalling everything.
Thank you again.
Hello. i would also need this information for the jumpers for the ps2 connection. Many Thanks
