585,748 active members*
3,753 visitors online*
Login Register
SolidCAM Forum
Hobby Discussion > Building a model jet engine
Results 1 to 2 of 2
    Nov 2019
    Hi guys, this is my second attempt to built a successful model jet engine , and have some critical questions about that.
    I attached some photos from my first attempt below if you want to take a look at. I believe that the engine was too small to self sustain, also i maid the turbine out of steel so it melted at the first start attempt :-( .
    Now am trying to built a model jet engine based on an old compressor from a car the size is 66mm.
    My questions are:
    1) How mach critical is the gap between the compressor its cover?
    2) Am trying to built the turbine out of stainless steel, I want to know if it is good enough to stand the high temperatures.
    3) What ball bearings I should use?
    Thank you very mach.
    Nov 2019
    Re: Building a model jet engine
    Also I will try to make some videos on my process, Go to the link below if you interested on that. Any advises would be helpful.
    https://www.youtube.com/watch?v=bmdzFXOby7g
  1. Building a Steam Engine
    By David Thomas Sr in forum Environmental / Alternate Energy
    Last Post: 12-15-2010, 12:08 AM
  2. looking for a VW engine model
    By dougtyler in forum Solidworks
    Last Post: 02-13-2009, 05:12 PM
  3. Looking for a 3D model of a IC engine
    By JerryFlyGuy in forum Community Club House
    Last Post: 06-06-2007, 12:00 AM
  4. 1/5 scale Model A engine
    By woodythx13 in forum I.C. Engines
    Last Post: 12-17-2004, 09:16 PM
