585,997 active members*
5,068 visitors online*
Login Register
SolidCAM Forum
Colchester Tornado lathes > colchester cnc 2000l elctrical manual need
Results 1 to 5 of 5
    Jul 2020
    3
    i have cnc 2000l, lubrication low indicator on but missing the lubrication flot switch input wire, i have not electrical manual ,please help me, which input lub level low ,wire no. and input no.
    Jul 2020
    3
    Re: colchester cnc 2000l elctrical manual need
    Sir pls
    Nov 2016
    9
    Hi surj i have same machine with similar problem.
    The lube lite comes off a float magnetic switch situated in the top box adjacent spindle. Looks like after a while the magnet just falls off the float so most people just permanently join the wires to continuously send the full signal.
    My lube lite is on and the wires are present and joined together however lube lite is still on so spindle wont run.
    There maybe a perameter to isloate it but finding someone to help is tricky.
    My guess is yours has been shorted in the control box and you have same problem.
    I did connect and disconnect wires and it worked one time and spindle started up.
    My guess is a sticking relay in box
    Richard
    Nov 2016
    9
    Quote Originally Posted by Richfromwilts View Post
    Richard
    It may help someone in the future.
    Turned out to be a dry soldered joint on the plug marked cl16 on the long white rack of 20x plugs
    inside the rear of the machine.
    This rack has a lot of cables hanging down which get moved during servicing. this is what made a poor
    connection inside the plug. Moving the cable got the lube light flashing.
    Also this long rack of plugs are all connected to the bank of relays approx 18x on the lower left side of the
    rear of the machine. These relays are all the same and not made any more but the equivelent is available.
    These relays are all connected to the row of plugs above and marked to match the relay.
    They control most switching functions on the fanuc control such as feed, lube, jog etc.
    If you get a fault with any of these not extingusing or failing most probably these small relays are sticking.
    Swap them over and see if the problem moves!
    I would love to get a wiring diagram for these machines for somewhere????
    Richard
    Hi everyone. I have Colchester 2000L with OT-A control. I need its electrical manual. Please help me to find its electrical manual.
    My email id is [email protected]
  1. Colchester 2000L
    By bertcnc in forum Colchester Tornado lathes
    Last Post: 06-25-2020, 07:40 AM
  2. Colchester 2000L CNC
    By Rathousekid in forum Colchester Tornado lathes
    Last Post: 05-08-2018, 07:47 AM
  3. colchester cnc 2000l parameter
    By kabdelwahid in forum Colchester Tornado lathes
    Last Post: 08-05-2016, 04:59 PM
  4. Colchester 2000L APC 310 and 320 Alarm
    By rjhzxc in forum Colchester Tornado lathes
    Last Post: 04-23-2014, 02:38 PM
  5. Need Parameters For Colchester 2000L CNC
    By Hakam in forum Colchester Tornado lathes
    Last Post: 10-27-2012, 02:46 PM
