586,013 active members*
4,019 visitors online*
Login Register
SolidCAM Forum
CNC "do-it-yourself" > TopCNC TC55H, can't import USB files
Results 1 to 2 of 2
    I have a Taig CNC mill I got on a trade, and put new stepper motors, drivers, etc on it. Got everything wired up and working, and got the settings tuned in so when I jog 10mm, it moves 10mm. I went with a standalone controller, as I seemed a good solution, and I'm familiar with that from years ago running a Haas mill and lathe.
    From the best I can tell, it reads .txt gcode files, and has to be named with a prefix of P followed by 4 numbers. So i've been playing around with different post processors on fusion 360, but when I try to import the .txt file from a usb to the controller, it freezes up. Google searches turns up minimal info on this controller. Does anyone have experience with this controller and how to import files to run?
    Re: TopCNC TC55H, can't import USB files
    I got some txt gcode to import, but it only imports 17 lines worth, and seems to be generating lines of code non-existent in the txt file. `
  1. Import .dxf files into NC500
    By niki2014 in forum CNC Machining Centers
    Last Post: 12-01-2019, 10:24 PM
  2. import CAD files into CNC controller
    By cnc-6824-Rainer in forum CNC-EDITOR
    Last Post: 09-10-2011, 08:06 AM
  3. import external files
    By huehnermopedfahrer in forum Uncategorised CAM Discussion
    Last Post: 07-10-2011, 01:05 PM
  4. Import DXF files directly into Mach 3???
    By Barefootboy4 in forum Mach Software (ArtSoft software)
    Last Post: 01-24-2011, 10:54 PM
  5. How to import ProE files in Solidworks
    By Tony888 in forum Solidworks
    Last Post: 07-03-2009, 05:05 AM
