584,860 active members*
4,947 visitors online*
Login Register
SolidCAM Forum
MetalWork Discussion > cleaning endmills of aluminum deposits with lye. yay or Nay?
Results 1 to 5 of 5
    Dec 2003
    189
    Smile cleaning endmills of aluminum deposits with lye. yay or Nay?
    I had over the years had many end mills and drill bits gummed up with aluminum do mostly to operator error.
    Question, Use Lye (Sodium Hydroxide) solution in water to dissolve gall deposits.
    Good Idea? or not so much?
    Is a sentance fragment?
    Re: cleaning endmills of aluminum deposits with lye. yay or Nay?
    a lot of guys claim to use drain cleaners to clean their carbide end mills of gummed aluminum . I haven't done it myself but I see no reason not to . The only thing I'd question is the reaction on a coated tool , I'm guessing it would probably have an affect on the coat . Either way it's worth a try since the only other alternative is to turf the tool .
    HSS I wouldn't bother
    Jul 2018
    6254
    Hi Tri -NaOH should be fine for removing Al from the steel tools. They soak AL extrusion tools in it to remove the solid AL so I think its fine for drills and cutters. Peter
    Dec 2003
    189
    This technique seems to work well on both Ti coated and carbide bits and end mills. Saved a bunch!
    Jun 2010
    4252
    I just poke with a carbide scribe. Works so far.
    Cheers
    Roger
  1. High-Speed Machining for Macros? Yay or Nay?
    By IsakAndersson in forum Haas Machines
    Last Post: 06-26-2021, 05:34 PM
  2. Replies: 3
    Last Post: 06-28-2020, 01:31 PM
  3. JCUT 1212A - Yay, or Nay?
    By jhank in forum Chinese Machines
    Last Post: 01-22-2017, 05:30 AM
  4. feed mills for my setup .Yay or nay ?
    By chrisnis in forum Benchtop Machines
    Last Post: 05-07-2013, 04:45 AM
  5. heating yay or nay
    By machinecrasher in forum MetalWork Discussion
    Last Post: 10-28-2011, 06:58 AM
