Today got off to a bad start - I guess I should've had a second cup of coffee, before wandering out to the shop. The first job I setup, I didn't correctly setup one of the fixture offsets, so on the first plunge, my poor endmill exploded. I grabbed another one out of the drawer, corrected the fixture offset and the tool length offset, and started over. Much to my surprise, I was getting pretty horrendous chatter, using the exact same G-code that worked perfectly most of yesterday. The only difference was the new endmill was a different brand from the ones I'd been using. I stopped the program, replaced the new endmill with the same kind that I exploded, and the chatter was gone!
Looking at the two endmills, I can't see any difference that would explains such a dramatic difference in performance. Very surprising.... Both endmills are 1/2" HSS 2-flutes with 1-1/4" length of cut. The "good" one is a Hertel, which is TiN coated. The "bad" one is an Interstate, which is not coated. Both are designed for cutting aluminum, have the same helix angle, and basically the same shape overall. I can't believe the coating alone could make so much difference. I used to use exclusively Putnam endmills, and really liked them, but I can no longer find them anywhere. They probably got bought by some other company.
Here are the two endmills:
Regards,
Ray L.
