I'm exporting my Viacad object to an STL. When I load the STL directly to Viacad, I can't even see or select an object. I know that the object is being created since I can load and view the same STL file in Bobcad. Does anybody do much with exporting their Viacad creations to an STL? It seems Viacad can't utilize its own export.
I played with the STL export settings but I'm still seeing a lot of folds/lines in the object (as I'm viewing it in BobCad). Will I see these surface imperfections when I print the object or are these just a side effect from screen viewing?
I just wanted to get some input before paying money to have this printed. I checked out the 3dstuffzone forum but this issue seemed to be pretty specific to Viacad. I have Viacad v8 standard.
Here I'm showing the picture. From Viacad, I don't see the same surface imperfections. Also, I put the STL export in a zip file.
