584,812 active members*
5,228 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
ViaCad / Shark > VC Pro Issue ?
    Jan 2006
    93
    VC Pro Issue ?
    when i hold CTRL when selecting 2nd solid, shouldnt it subtract from the 1st and 2nd stick around, but when i move 2nd object the subtraction goes away after i let off mouse button. v8 or v9. am i doing something wrong? if i select sphere 1st, then CTRL click the cylinder, a portion of sphere is subtracted off and when i move sphere the subtracted section is indeed subtracted.
    Jan 2006
    93
    this is normal. apparently its not a static subtraction using it this way. i dont quite get the functionality, seems to be the same as two solids intersecting. it can be made static by Edit >>> Remove Links from the 1st solid. but doing this removes other things, which may not be desirable.
    Oct 2008
    2100
    Often I need to do a subtract and still have the original subtracted object. I use a Ctrl+C - Ctrl+V in place. Its not elegant, but it works. It can be quite slow if its a complex object.
    Bob La Londe
    http://www.YumaBassMan.com
    Jan 2006
    93
    Quote Originally Posted by Bob La Londe View Post
    i see the need to add a control key, perhaps ctrl+alt when selecting the 2nd object, this would do static subtraction w/o linkage, which in my mind is a simple subtraction w/o deleting the 2nd object. voila, a no fuss fix.
    Dec 2008
    4548
    Re: VC Pro Issue ?
    Quote Originally Posted by CNC_Kid View Post
    What you are seeing is a history, or "dynamic geometry"..... The sphere get an attribute of "be a cutter on this object" (The link)..... When you move the sphere away, it is no longer cutting the object. In your first scenario, if you move the cylinder away, you will see it is indeed cut..... (That's what you are describing in the second scenario...
    You found the answer, but you also mention that removing links was "undesirable" in circumstances.... You described using "edit-remove links", which is kindof a global operation... What you want to do is go to "window-concept explorer" and then select object, to view it's "history" so to speak.... You should be able to find the "single link" you want to remove, without removing "all links" like you described...
    Anyway, become familiar with the concept expolorer....
  1. Another issue
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 03-23-2012, 08:13 AM
  2. Cambam issue or Mach 3 Issue??
    By tracyranson in forum CamBam
    Last Post: 07-11-2011, 04:03 PM
  3. will this be an issue?
    By stk2008 in forum Stepper Motors / Drives
    Last Post: 09-17-2009, 04:35 PM
  4. Help with selector switch wiring issue (***actually a motor issue***)
    By BEDFORD in forum Charter Oak Automation Support Forum
    Last Post: 04-07-2006, 09:19 PM
  5. THC Issue
    By Aldoseri in forum CamSoft Products
    Last Post: 01-31-2006, 11:33 AM
