584,874 active members*
5,234 visitors online*
Login Register
TDM Systems Forum
Digital. Experienced. Powerful. - 100% Tool Management
ViaCad / Shark > Cant seem to stop my holes from snapping in the wrong direction.
Results 1 to 8 of 8
    Jun 2013
    443
    This example is a small gusset that will bolt on through the front face. The front face angles downwards. I would like the counter bore hole to be perpendicular with the rear face of my part. So when I bolt the part on the bolts are straight into the face behind the part. But what happens is the hole, no matter what I do, snaps to the front face, and angles down. If I drill from the back, its straight and perpendicular but I cant counterbore.
    Hard to explain so I have attached two images one in solid and one in lines.
    I have tried all SharkCad hole settings. The "normal" is the only one that will actually drill a hole. The others do nothing.
    Anyone know how to resolve this? Even the two point hole setting does not work.
    Jun 2013
    443
    Re: Cant seem to stop my holes from snapping in the wrong direction.
    After ages I found the solution. Use a 2 point hole. Its just VERY sensitive with the snaps.
    Attached Files Attached Files
    Jul 2010
    178
    I love shark. Such cool software.
    Jun 2013
    443
    Sorry Mr Farmer. I disagree. It imports STEP files as imperial - the developers know about this bug and won't fix it. Also, Shark regularly and often crashes without warning. Yeh 5/10 for me. Tho the price was good.
    Sent from my SM-N970F using Tapatalk
    I'm guessing that shark is as broken as the viacad pro version . It's well set up to be a killer program and they could be at the top of the affordable market if they gave a S@$% about their customers and the software .
    They need to ditch their pet project powerpack and focus on fixing the software .
    Jun 2013
    443
    Ha. Agreed. That's funny. Every time I find a bug they try to sell me an upgrade. (started with ViaCad, last version I was sent was Shark Pro)
    The STEP metric to imperial bug, they showed me the bug, but stopped talking when I asked them to fix it.
    But it's not all bad. I save every 5min when solid modeling. I "usually" remember to convert to metric when I import into Fusion.
    I do have to say though that every time I contact them with other problems they have helped immediately.
    I think it depends on who a guy talks to . I had a good conversation with one of the guys who was helpful at addressing a major problem with the software . But , overall the software falls apart more with each version . I've been using since v5 and I've learned when to save before making the next move which may or may not crash the software .
    I love the features , I just wish it was more stable
    Jul 2010
    178
    Quote Originally Posted by boydage View Post
    I always model in Shark and then CAM in Fusion. But if I ever need to add some geometry for machining, in DESIGN the model defaults to inch even though I have mm set as default. I export from Shark to STEP but have no option for the unit. So is this a Shark issue or a Fusion issue?
  1. Homing in wrong direction
    By Paul714 in forum Mach Mill
    Last Post: 01-29-2019, 07:38 PM
  2. My homemade CNC router cant cut holes as it should? Anyone know what can be wrong??
    By kayakman in forum Uncategorised WoodWorking Machines
    Last Post: 02-25-2017, 01:54 AM
  3. Cut off spindle direction wrong
    By WOTDesigns in forum Mastercam
    Last Post: 02-15-2016, 04:17 PM
  4. Y AXIS WRONG DIRECTION
    By cncbeastmaster in forum Haas Mills
    Last Post: 11-24-2014, 05:21 PM
  5. Need Help! Y-axis wrong direction
    By ponte in forum Redsail Laser
    Last Post: 08-10-2013, 03:07 AM
