LMT Lab Days represented the largest international gathering of the dental laboratory community in North America and WorkNC Dental presented again this year
as well as on the booths of partners, Datron Dynamics and Zahn Dental.
Visitors to the Sescoi booth have seen the latest release of WorkNC Dental advanced CAM software for milling dental components, designed to help provide laboratories with the lowest costs to milling quality dental prostheses. Features such as multi-threading, parallel processing and batch processing enable fast calculations, while customized templates and part setups allow more parts per block/puck of material to be milled. WorkNC Dental CAM milling algorithms, the result of over 25 years of advanced milling research, ensure shorter run times on the milling machine.
Additionally, WorkNC Dental experts demonstrated the latest developments in the WorkNC Dental Implant Module, which enables advanced, efficient milling of all implantology components. This module enables the automatic detection of implant styles, which can also be directly read in from the dental scanner and CAD system.
Due to the use of solid model topology as well as the scan technology, implants have the best fit and accuracy possible.
Dental practitioners wishing to produce their own custom abutments, implant bars and bridges, using a fully open solution, can learn about the full process from the WorkNC Dental team at the LMT Lab Days and view live cutting on a Datron milling machine.
Responsible for the content of this press release: Sescoi GmbH
