504,045 active members
4,815 visitors online
Login Register
WALMAG MAGNETICS s.r.o. - Banner
WALMAG MAGNETICS s.r.o. News
BM Lifting magnet
The battery operated BM lifting magnet has a wide spectrum of uses. It’s ideal for dispatching, warehouses, and operational purposes. It is ideal for lifting plates and blocks and also for working with various workpieces, castings, and forgings. Thanks to a built-in 12 V battery, the magnet can be in operation for up to 8 hours at 50% duty cycle. Just like with most of our magnets, we put great emphasis on safety. Visual and audible alarms indicate that the battery is low. The new control unit is equipped with Variable Force, which is able to set the holding power for a specific number of plates in a bundle. The Tip-Off function ensures the gradual release of the load. (” sheeting”) The remote control, which you can use from up 10 metres away, enables to use the magnet in places with limited access work in places where it is difficult to control the electromagnet with the buttons directly on the unit.
Responsible for the content of this press release: Walmag Magnetics s.r.o.
Contact
Hulínská 1799/1
76701 Kromeriz
Czechia
+420 573 341 641
Route planner
Route planner
