1 Attachment(s)
3d STL error opening
Hi all,
I was working on a model and everything was fine and opening. Then I re-opened a file and tried to make g-code. It said error could not open and it says error producing solid face. Here is an example part. Does it open for you, when you open from toolpath, surface, then select CAD as y, and then any toolpath and then open it.
Thanks. :)
What I'm trying to say is that it opens fine sometimes while not fine at others.
Thanks. :)
hmmm, it seems that sometimes it works, others it doesn't. I restart my computer do the exact same thing, it works, then try again and it doesn't. Not sure what the problem is.
Thanks though. :)
In V9 it seems to only work once in a while.
Thanks. :)
I was asking as VX seems to support it better.
Are you running Just V9 or say V9.1sp2 or later being Maintance releases? There had been some updates on this issue.
