587,409 active members*
3,369 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3d STL error opening
Results 1 to 7 of 7
    Mar 2004
    500
    Hi all,
    I was working on a model and everything was fine and opening. Then I re-opened a file and tried to make g-code. It said error could not open and it says error producing solid face. Here is an example part. Does it open for you, when you open from toolpath, surface, then select CAD as y, and then any toolpath and then open it.
    Thanks.
    Attached Files Attached Files
    Mar 2004
    500
    What I'm trying to say is that it opens fine sometimes while not fine at others.
    Thanks.
    Oct 2004
    116
    It opens fine for me
    Mar 2004
    500
    hmmm, it seems that sometimes it works, others it doesn't. I restart my computer do the exact same thing, it works, then try again and it doesn't. Not sure what the problem is.
    Thanks though.
    Apr 2003
    3578
    is this in V9 or VX?
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Mar 2004
    500
    In V9 it seems to only work once in a while.
    Thanks.
    Apr 2003
    3578
    I was asking as VX seems to support it better.
    Are you running Just V9 or say V9.1sp2 or later being Maintance releases? There had been some updates on this issue.
    Cadcam
