Question: is the lines under machine/measure/"Edge ..... and Probe calib." exluded from (language)*.txt file purposefully ?
I am using fast buttons in "Bottom btn" but could not add this new ones...
Printable View
You don't need language file to create button files.
If you just need command name then you can type "=cmdlist()" into MDI and you'll get full list in output window
Is it intended that the machine no longer moves to the measured position after measuring. Unfortunately no documentation on this.
Yes, this is by design.
All unwanted moves were removed from measuring routines. No more dangerous travels to safe height. And compatibility with CAM postprocesors.
Ok, I'll try, but still would like to convert to my native language:)
1. You can add those moves to script.
2. You can use old scripts. I'll post updated old scripts in few days, along with some small fixes in software..
3. You can get used to new much more practical scripts.
sucsess! made all butons I need :wave:
The main problem with the new scripts is that its impossible to null the axis if you use a touchscreen.
The Axis needs to be at the null position for this.
New version sets:
$<cmd_setworkoffset> and
$<cmd_setcsoffset>
variables. You can edit measure scripts and add them after G65 code in measure scripts.
