Loading Program trough RS232
Hi All
Acramatic 2100 I ran into an issue while loading programs.
When I start the machine I have no problems sending program to machine via RS232. After about 20 minutes. I get an error (Not able to read file) Not sure what is going on
Also I loose my touch screen about the same time. I had the KTI 2 Board replaced.
Is there a connection between the two since the both connect to the workstation . Tried a different workstation same result.
Could it possibly be a cable
Thanks Joe
Re: Loading Program trough RS232
The problem might come from the CNC or PC or Cable connection.
Since the touch screen also failed, then most possibly the problem from the the CNC side.
