I'm trying to do edgelit designs in plexi but I can't seem to stop the stuff from melting.
I've had the best luck with 2-flute 0.048 ball nose cutters, but only for a short while. Inevitably after a time the plastic starts to melt and load up on the cutter and either I have to stop the job, chip the plastic off and restart, or snap the cutter trying.
I like the little 2-flute roundovers because they leave a nice clean cut in the plastic. I've tried engraving cutters but they look like crap (and similarly load up); and a few rototool (Dremel) cutters but they load up even faster.
I have tried very slow feed and very slow speed, very high speed and feed but eventually the cutter always loads up
Is this a problem with the wrong cutter? I feel like there's a magical 0-flute 048 ballnose cutter with an 030 cutting depth (so sort of a triangle tip) out there but I have yet to find it.
Or is this a problem with my feeds and speeds? I definitely don't have any problems cutting outlines in the plastic using larger (1875) 0-flute cutters so the root of my problem is the minuscule size of the cutter I need to use to get the detail I want. But since I've tried really fast and really slow I can't imagine there's something in between that would work.
I am thinking about setting up an air system and blowing cold air across the piece as I cut. That would take a lot of work but I'm willing to do it if it solves the problem.
Anyway, suggestions are greatly appreciated,
Thank you,
