603,348 active members*
3,870 visitors online*
Results 1 to 10 of 10
    Jun 2021
    4
    Re: Polycarbonate woes
    Yes, you're absolutely right, I meant plexiglass, not Lexan. If I stuck to the brand names I'd be fine :-)
    Weirdly I can't seem to edit the original post.
    I'll give the chiller a try.
    Thank you,
    Apr 2018
    166
    Quote Originally Posted by dmetzler View Post
    Moderator note: There is a 60 minute window from the initial post to edit that message. Its unfortunate that this is necessary, but otherwise spammers would make the forum very unpleasant. Their technique is to post an innocuous message, then later go back and edit the message to insert spam links. This pattern is very difficult to detect/block with the current vBulletin forum software. So the one hour edit limit cuts the spam down to a mostly manageable level.
    - - - Updated - - -
  1. Machining Polycarbonate
    By jdwhittaker in forum Glass, Plastic and Stone
    Last Post: 11-14-2014, 11:04 PM
  2. Milling Polycarbonate
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 09-01-2012, 05:06 AM
  3. Hardened Polycarbonate
    By pointless in forum Material Machining Solutions
    Last Post: 07-18-2007, 03:00 AM
