Have some questions about Amada laser G code
Hey all!
I run an Amada Regius ML3015 FOL at work. It's a 6K machine.
According to Amada, because they're stand alone machines that aren't hooked to automation, we can't make regular nests with multiple layouts and just run them, and we can't auto repeat a program, we have to wait for the machine cycle to finish, and press start manually for as many times as we need to run a layout.
I've discovered changing the "M30 stop and reset" at the end of the program to an "M97 repeat" will have it loop the same program infinitely until I manually stop it.
My questions are these:
How do I get the machine to run the macros for the nozzle clean / height calibration and nozzle check / auto centering at the beginning of every program repeat, before it does the sheet detection?
Also, is there a line I can add besides that "M97" that will let me run a program "X" amount of times, then stop automatically?
Thanks for any help!
Re: Have some questions about Amada laser G code
Use the schedule function to run the program a certain number of times
