603,308 active members*
2,873 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Have some questions about Amada laser G code
    Hey all!
    I run an Amada Regius ML3015 FOL at work. It's a 6K machine.
    According to Amada, because they're stand alone machines that aren't hooked to automation, we can't make regular nests with multiple layouts and just run them, and we can't auto repeat a program, we have to wait for the machine cycle to finish, and press start manually for as many times as we need to run a layout.
    I've discovered changing the "M30 stop and reset" at the end of the program to an "M97 repeat" will have it loop the same program infinitely until I manually stop it.
    My questions are these:
    How do I get the machine to run the macros for the nozzle clean / height calibration and nozzle check / auto centering at the beginning of every program repeat, before it does the sheet detection?
    Also, is there a line I can add besides that "M97" that will let me run a program "X" amount of times, then stop automatically?
    Thanks for any help!
    Apr 2021
    46
    Re: Have some questions about Amada laser G code
    Use the schedule function to run the program a certain number of times
  1. Replies: 0
    Last Post: 04-19-2020, 01:19 PM
  2. Replies: 0
    Last Post: 01-15-2019, 03:20 AM
  3. Replies: 0
    Last Post: 07-02-2017, 02:39 AM
  4. G code generator for AMADA laser machine
    By kikitron in forum Uncategorised CAM Discussion
    Last Post: 11-02-2016, 05:00 PM
  5. Amada Pega344 g-code
    By mnadi121 in forum G-Code Programing
    Last Post: 05-28-2011, 09:17 AM
