I have THK SHS 45 and HSR25. I have hard time finding the grease zerk. I really don't know what size is the zerk. Does anyone use of that and have reference to that zerks?
Printable View
My catalog shows B-PT1/8 for the SHS 45. That’s British Standard Taper Pipe. BSPT -1/8”
HSR 25 shows an M6 metric port. That will be standard M6 x 1mm pitch.
Regards Phil.
Rocky
Some guys I recommended this company too had good results when they were looking for some BSW bolts.
http://www.britishfasteners.com/mm5/...egory_Code=300
You could try a NPT, I’m sure that’s been done; yours are 27 TPI the British will be 28 TPI. Although you will probably get some crap in there from the cross threading.
You will have more luck finding them if you look for “grease nipple” rather than Zerk. That’s a particularly American term.
McMaster Carr also have them. Page 2133, of the catalog. Part Numbers 2408K11, 2408K12, 2408K14, & 2408K13.
Regards Phil.
