603,783 active members*
2,686 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Grease Zerk For THK bearing block.
Results 1 to 4 of 4
    Jul 2008
    68
    I have THK SHS 45 and HSR25. I have hard time finding the grease zerk. I really don't know what size is the zerk. Does anyone use of that and have reference to that zerks?
    Aug 2004
    15
    My catalog shows B-PT1/8 for the SHS 45. That’s British Standard Taper Pipe. BSPT -1/8”
    HSR 25 shows an M6 metric port. That will be standard M6 x 1mm pitch.
    Regards Phil.
    Jul 2008
    68
    Quote Originally Posted by Machtool View Post
    Regards Phil.
    I don't think I am going to one in the USA but the M6 should be no problem.
    Rocky
    Aug 2004
    15
    Rocky
    Some guys I recommended this company too had good results when they were looking for some BSW bolts.
    http://www.britishfasteners.com/mm5/...egory_Code=300
    You could try a NPT, I’m sure that’s been done; yours are 27 TPI the British will be 28 TPI. Although you will probably get some crap in there from the cross threading.
    You will have more luck finding them if you look for “grease nipple” rather than Zerk. That’s a particularly American term.
    McMaster Carr also have them. Page 2133, of the catalog. Part Numbers 2408K11, 2408K12, 2408K14, & 2408K13.
    Regards Phil.
  1. Linear bearing grease
    By Claude Boudreau in forum Linear and Rotary Motion
    Last Post: 04-11-2008, 05:33 AM
  2. How to cut a bearing block ?
    By ringram2077 in forum MetalWork Discussion
    Last Post: 04-03-2008, 03:49 AM
  3. Help with bearing block
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-11-2007, 10:47 PM
  4. Which Bearing grease?
    By skyline in forum Linear and Rotary Motion
    Last Post: 04-15-2007, 08:10 PM
  5. Bearing Grease
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 06-06-2005, 10:07 PM
