Re: Amada pega fanuc 04pc system error
Hi Ajay,
Assuming your controller is 04PC ......check adjust the X axis Grid shift Parameter No. 82 ......
the value of this parameter can be positive or negative ......... ( Note the initial value ) and change as per your requirement.
**** we provide all kind of Troubleshooting & Maintenance Services for CNC Turrets , Lasers & Press Brakes. Let me know if needed......!
Get in touch on [email protected] ( 9404222266 / 8554014614 )
thanks.
Thanks Mr. Pitre,
Will check and revert in a day. BTW what is your location in India, I am at 200 KM from Delhi, in Haryana.
Thanks a lot for your help.
Regards,
Ajay
Hi Ajay,
I am based in GOA .....25 kms.....from the capital Panaji......
Thanks a lot Mr. Pitre,
The machine is working fine now, but some time we are facing a problem... the holding down clamps will not come down to hold the sheet while repositioning and alarm 2042 W Dog Timer (M10-01ExEcMF TF-EF) appears on the controller.
Can you please guide?
Ajay
Mr. Ajay
This is Deepak from mumbai.
I just want to know that you are talking about clamps or work holder? if you are talking about work holder then you have to check the valve or clean the cylinder.
You can call me :- +91 9222018538 / +91 8149636586
we dealing in all kind of Troubleshooting & Maintenance Services, Retrofitting, Installation for CNC TPP, Lasers, HMC, VMC, VTL Etc. Let me know if needed......!
Get in touch on [email protected] / [email protected]
Thanks & Regard's
Deepak
Hello Mr. Deepak
Thanks for your support, will get the valve clean today and let you know the outcome.
Sure, will get in touch if I need your help.
Ajay
My Amada machines lost all parameters because of long electric failure and the batteries did not hold.
When the power was restored the Amada machines already had lost everything.
Amada Apelio II 357 05PLA( Combi machine Laser Punch )
Amada Pega 244 04PC ( Punch Machine )
Do you have backup parameters for this machines if possible also the MMC parameters.
Quote:
Originally Posted by
Barbwier
My Amada machines lost all parameters because of long electric failure and the batteries did not hold.When the power was restored the Amada machines already had lost everything.Amada Apelio II 357 05PLA( Combi machine Laser Punch )Amada Pega 244 04PC ( Punch Machine )Do you have backup parameters for this machines if possible also the MMC parameters.
I am sorry for replying late, but my machine is Pega 344. Will it help?
Pitre
hi...
I shall be re-installing one Apelio machine after couple of weeks....I can help you at that time.
you will have to wait till then.
I sent him parameters for both machines. Hopefully it work out.
Hello,
I am servicing a Amada Pega 345 with Amadan 04PC and The machine is not getting the signal for the TDC, I checked the sensor and it is working, even the signal is in the card, I am looking for documents where i can see how the signal goes from one card to another to see if the wire is broke
jorber
Hello,
I sent reply, I dont see it posted.
1. Check wires P2-N2 should be 24VDC
2. Check diagnostic 2008.4, is it 0 at TDC? Put steel in front of switch on / off will diagnostic 2008.4 change? Jog ram off TDC to get cam out of your way for testing
3. King Or Queen machine? Queen has hyd clutch
4. Open door with main breaker. Large board inside at top of board should have number TCU1, is it A,B,C? Different schematic for each.
AMADAJOE
Hello.
1. The 24v is Ok
2. The diagnostic 2008.4 is not changing even in the sensor the LED I can see lightning when put the metal in front. Also I see the leds in the board as in the picture.
3. Is Queen
4. Now I am away to see that but let you know later
https://uploads.tapatalk-cdn.com/201...6b5bc7d098.jpg
AMADAJOE
The Board is TCU1C-00Ahttps://uploads.tapatalk-cdn.com/201...b3a53eca17.png
[QUOTE=jorber;2218266]The Board is TCU1C-00Ahttps://uploads.tapatalk-cdn.com/201...b3a53eca17.png
TCU signal Wire #156 comes into TCU1 board on TM1 Pin 6.
signal comes out TCU1 M18 Pin 17.
See if you have signal change in and out of TCU1.
[QUOTE=AMADAJOE;2219020]
jorber
Hello,
The problem is in the output of the TCU1 without a metal on the sensor is 22V with metal is 24V.
Who is handling that output?
1 Attachment(s)
AMADAJOE
Where is located OPT1?
I couldn’t find it
1 Attachment(s)
AMADAJOE
Ok, then could be PHT4 or PHT1 right?
https://uploads.tapatalk-cdn.com/201...282649ad15.jpg
