Originally Posted by
Fagor - Todd
With a standard accuslide, you do not have a lot of M-code outputs..... spindle M03/04, M08/09 coolant and I think they called it M13/M14 for collet open/shut and maybe a few others.
If you want to trace it out, go to the I/O 2 port on the CNC. (It is the only 25 pin connector on the CNC)..... take the connector housing off and trace all wires that are connected from pins 3 thru 13 and also pins 22-25...... a lot of them should have no wire connected because I know they did not use all M-code outputs. Once we know where they go, I can tell you how to set-up the M-code table. The connector is on the back of the CNC on the pendant. (The 8025 is a compact CNC and is all 1 unit) the wires will then undoubtly run thru the arm and into the electrical cabinet.
My next question, is parameters..... do you know them ? Have you re-entered them ?
After you are all done, I'll teach you how to back this data up so you can just do a reload in the event of future problems.
Todd
