Re: 6'X12' DynaTorch build log
Just thought I would give an update on the retro fit we did 6 years ago.
At the time Dynatorch was using the animatics servos and refusing to fix the problem. They decided to change to a different system and let the existing Dynatorch table users on their own with no resolution or solution other than buy into the new system. We had already accumulated $2.2k in shipping cost plus over $8k in motor costs. My decision to leave the dynatorch platform was based on a motor I sent directly to animatics for a analysis of the failure. Animatics in no uncertain terms laid the fault on the manufacturer claiming the motor was "backdriven" and reverse voltage applied.
Dynatorch had no solution, mechanical, technical or financial for us or the MANY other users claiming the same issues.
I enlisted the help of Tom Caudle from CandCnc and he steered me to a servo system called the PlazPak4+. I am running said system today. any problems I have encountered have been user error (or stupidity ??) on my part . Zero warranty claims, zero tech support after system was installed. Six years now. I still run the same table everyday.
It just works! It has some odd behaviors, such as being bluetooth intolerant, but cuts the same or better as the day it made it's first cuts. No tuning needed to switch between 10ipm oxy cuts or 180ipm on thin aluminum.
A simple update to our hard working system.
Cheers!
WSS
Quote:
Originally Posted by
WSS
Cheers!
WSS
Thanks for the update. I recall your headaches the DT. That poor support sours a guy from ever going back to the table.
Tom Caudle understands customer service too
Tom Pace
Sent from my Nexus 6P using Tapatalk
PlasmaGuy
Tom Pace
Wow WSS, you still using that plasma every day? :eek: Someday if you ever decide you might want to upgrade it to a later control system get in touch with me. The controls have evolved and the Software, and hardware are all in their 5th generation. We went to LINUX over a year ago and the current DTHCIV is many times faster and more responsive than the MACH3 version you are running.
Torchhead
I know it's coming. I'm still running xp and an old refurbed dell optiplex you sold with the unit. Will your new system work with my Hypertherm 1650 (running a duramax torch)?
Hi WSS,
Give me a call and let me know if I can help with anything.
It's been awhile since we talked and I'm just curious how everything is going
Gary Wittlock
WSS
YEP!. In fact we can probably just update the front end controls and you can continue to use the power section , drivers and motors.
gwittlock
Hi WSS,
Gary Wittlock
Hello Gary! Everything is going good. V21 is getting easier for me know. Once I realized that I was still referencing v20 database, all the lights turned green.
When our shop slows a bit this winter, I'll connect with you for some short(er) cut training.
WSS
Torchhead
I need to do this soon. I have threatened to quit cutting a few times lately to focus on managing our Carbide surfacing shop, but some job shows up that I cannot refuse ($$) and off I go cutting again.
WSS
HI WSS,
As always I will be ready when you are. I will be waiting for your call.
