Horn
1118
Horn
1118
New geometry for finishing grooves
MarketingHartmetall-Werkzeugfabrik Paul Horn GmbH on March 23, 2021 at 3:52 PM
Paul Horn GmbH is proud to present FB geometry, a solution for finishing grooves. By standardising the special cutting geometry, Horn is responding to users’ requests for even better surface quality on the flanks and at the base of a groove or recess. This geometry has already been in use successfully for some time as a special solution for producing grooves for sealing rings and shaft seals. High surface quality is possible without any problems in the finishing process, even when the conditions are unstable. Horn offers the geometry for a variety of systems for external and internal grooving.
The geometry is available as a standard tool for the 224, 229, S34T, 315 and 64T systems for precision machining of external grooves. For internal machining, it is available for the 105, 108, 111, 114 and 216 systems. Further insert types are available as special tools and can be delivered quickly via the Greenline system, whereby it is possible to deliver up to 50 customised inserts, depending on the design, within five working days after approval of the drawing by the customer.
