Vision Wide Tech
5
Vision Wide Tech
5
ADM series 5-axis Composite Material Machining Center
vision-wide news Image
ADM is a 5-axis machining center to process composite materials with high speed, precision, and automation. ADM is aimed at processing materials such as Carbon Fiber Reinforced Polymer (CFRP), Fiberglass, Plastic, and Aluminum.
  • Rapid spindle
  • Dual ATC magazines
  • Synchronized 5-axis machining
  • Ultra-low temperature spiral tube cooler
  • Auto pallets changer
  • Enclosed splash guard (with roof)
  • Laser positioning sensor (Opt.)
  • Spindle and ground suction device
https://www.visionwide-tech.com/en/pro_adm_01.html#tab_specifications
Responsible for the content of this press release: Vision Wide Tech Co. Ltd.
