Vision Wide Tech
5
Vision Wide Tech
5
ASM series 5-axis Universal Machining Center
vision-wide news Image
ASM is the first 5-axis CNC turning and milling machining center of Vision Wide, and it is particularly designed for delicate cylindrical components machining featuring high acceleration, rapid feed-rate, and synchronized axes machining, especially for aerospace components, tire molds, turbine blades, and aluminum parts.
ASM accessorizes with 5-axis universal head and rotary shafts built-in D.D motor. Through topology analysis, ASM realizes the best distance between the tool center point and B-axis transmission.
Responsible for the content of this press release: Vision Wide Tech Co. Ltd.
