Vision Wide Tech
5
Vision Wide Tech
5
GSF series -5-axis Gantry Type Machining Center
vision-wide news Image
GSF Series 5-axis Gantry Type Machining Center, provided excellent 5-axis simultaneous accuracy performance for 5-axis machining in mold cutting, highly precise contour finishing, milling, drilling, and tapping. Vision Wide manufactured the 5-axis machining center to shorten tool displacement travel and cutting process effectively and extend tool life and offer the best choice for composite angle machining. GSF Series had an excellent dynamic performance on one-piece structural and equipped high accuracy 2-axis head to achieve 5-axis simultaneous accuracy performance.
  • Continuous 2-axis head
  • 5 axis dynamic rotation synchronization accuracy (TCPM) 0.04mm.
  • Built-in Spindle Direct-Driven on B&C axis, 15,000rpm spindle speed.
  • Backlashless driving on B/C axis, Rotation Positioning accuracy ±5”.
  • Low table height, closer operating zone, and wider door width are convenient designs for users.
  • Chain type chip conveyor (standard) is able to remove iron chips efficiently.
Industries Applications:
  • Aerospace-Aluminum Frame
  • Automotive- Stamping Die
  • Mechanical Component
https://www.visionwide-tech.com/en/pro_gsf_01.html
Responsible for the content of this press release: Vision Wide Tech Co. Ltd.
