586,075 active members*
4,320 visitors online*
Login Register
CHIRON Group SE Forum
PERFORMANCE MEETS PRECISION
RFQ Feedback > Drilling Alloy 20, 31% nickel, very gummy
Results 1 to 3 of 3
    Sep 2013
    3
    We are currently working on a new project, drilling .051"-.056" diameter hole through a 1.400" long shaft in our Citizen M32 swiss lathe. The material is Alloy 20, the drills are Mitsubishi carbide(I forget the exact style). We have had limited success with the drilling, chipped tools poor finish (i should mention the finish requirement of 63 microinches) etc, with tool life being the biggest challenge.
    We have subcontracted gun drilling, but due to cost and added complications to the remaining machining operations, this is not ideal.
    Any sugestions or recommendations are appreciated.
    Chet Pierce
    Feb 2009
    6028
    Used to turn a lot of nickel alloys. Tool life is always bad. Found the old kennametal k68 carbide was better than most. We used sumitomo new point drills (sharp edge, not honed edge) and could only get 10 parts per drill, even with HPC. The alloys we turned were tough though, nickel with titanium and a few other nasties.
    15362
    Medmach
    If it is not being used in chloride solutions, which alloy 20 is good for, then go with 416ss this is very good to machine
    Mactec54
  1. milling nickel 200?
    By bebob1 in forum MetalWork Discussion
    Last Post: 05-18-2012, 10:39 PM
  2. Gummy 6061 Aluminum Rod - Heat Treatment Options?
    By cjjonesarmory in forum MetalWork Discussion
    Last Post: 08-09-2010, 01:49 AM
  3. replating nickel
    By norvil1 in forum Material Machining Solutions
    Last Post: 10-29-2007, 10:41 PM
  4. Nickel plated table
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2005, 06:29 PM
  5. Nickel Silver
    By scottsss in forum MetalWork Discussion
    Last Post: 04-26-2005, 10:52 PM
