Hello guys
i need help from you and i hope you can answer me as soon as possible
first of all you need to know that im using Mach3 plasma machine that i built it and am having a problem with it
every time i try to operate it , it works good and every thing is perfect without the torch on , but the breakout board disrupts when the torch goes on and i dont know why thats happening , its been the third time i change the breakout board but it still disrupts (by the way the breakout board works fine with torch on when i use the Hypertherm plasma cutter but it disrupts when i use the ESAB pcm-875 )(and another thing the Hypertherm plasma cutter disrupted thats why i changed it with the esab cutter)
please if you know the answer tell me soon
and thanks for who ever helps me
