586,551 active members*
3,318 visitors online*
Login Register
CHIRON Group SE Forum
PERFORMANCE MEETS PRECISION
Fanuc > Buttons do not work (Fanuc)
Results 1 to 18 of 18
    Sep 2015
    48
    I started a machine that is standing for a long time.It is a lathe that has a control unit Fanuc 10T. Machine is functional if you stood long.I noticed that the buttons do not work "P" i "3" and buttons "offset" under the monitor.At beginning "offset" button worked but now no longer.During one point machine it worked and button "3", but not for long. What could be?I cleaned with contact spray for motherboard, I did not get anything.
    Whether to replace them with buttons that do not use?Or to try something else?I can now insert images, site does not work I'll put in as soon as I could..
    Sep 2015
    48
    Re: Buttons do not work (Fanuc)
    After thorough cleaning I could not do anything. Checked each switch button eith UNI and each works perfectly.Every opportunity compression gives contact, the problem is something else.I switched from another machine all thekeybord (front control unit) and I got work keys 3,P and offset but it did not work second X,O,CAN,SHIFT,7.Both machines do not work for very long, do not know what could have been.I do not know what else could see...I changed and flat cabel the same happens.I do not know what else to lookAttachment 300198Attachment 300200Attachment 300202
    Sep 2015
    48
    Help! Help! Help!
    Jun 2008
    4
    Compressed air, contacts spray. Cleaning contacts with rubber, contact spray again. It's my formula.
    Sep 2015
    48
    Quote Originally Posted by lp_felix View Post
    I tray, but noting
    Sep 2015
    48
    After thorough cleaning I could not do anything. Checked each switch button eith UNI and each works perfectly.Every opportunity compression gives contact, the problem is something else.I switched from another machine all thekeybord (front*controlunit) and I got work keys 3,P and offset but it did not work second X,O,CAN,SHIFT,7.Both machines do not work for very long, do not know what could have been.I do not know what else could see...I changed and flat cabel the same happens.I do not know what else to look
    - - - Updated - - -
    Mar 2007
    2083
    it will be easier if you have the circuit diagram for the PCB with the key switches on
    the circuit would make it possible to see if you have random switches not working or if they are all connected to one wire
    tracing the connections between all the switches and the cable connector should be easy , it just takes time
    as an example
    Attachment 300636
    the diagram shows a 16 key matrix that only requires 9 wires to connect the keyboard to the encoder IC
    if the connection to terminal X3 was broken
    keys 2 , 6 , 10 , 14 and 18 would stop working
    I assume you have measured the contact resistance of the switches and its less than 1 ohm
    since you have tested the switch panel on another machine using another cable
    I would suspect you could have a poor solder joint or a cracked copper track on the keyboard PCB
    or corrosion on the cable connector
    John
    Sep 2015
    48
    I not have diagram, but I tray to find it.We tried test every switch and provides a signal. Since I have two machines I switched set the control unit from another machine (no 2) and got to work Offset,P,3 but it did not work second X,O,CAN,SHIFT,7.When I changed cable (all who go to these boards up) did not get anything.I have inserted plates from another machine (no 2) (see picture) I changed one to one behaves like the beginning (p,3,offset).The machines have a long standing some 11 years, but everything else works nicely. First machine it is complite (have transformator), the second is not complete.
    Attachment 300664Attachment 300666Attachment 300668Attachment 300670Attachment 300672Attachment 300672Is it possible that she lost some parameters?it was not plugged in 11 years.As soon as I turned I changed batteries,and I wrote programs and omissions piece works well...I guess it has not lost any parameters.Whether something about the keyboard is back in the closet?The problem is that I do not have any support from masters in the country.lSorry for my bad language, I hope you understand me
    Sep 2015
    48
    Machine is Ikegai fx10zAttachment 300674Click image for larger version.
    Feb 2011
    640
    just keep pecking at the button 100 times or so...if they sit a long time they often dont read.
    weve had a lot of 0 controls stored that acted up after sitting- just last week a brand new keyboard from fanuc wasnt reading a bunch of keys, just kept tapping on them and eventually the contacts cleaned up and they work fine...switches are fairly durable, but arent the quality of the old 6/11 with the actual keys- those things and their bubble memories can be booted up after a decade and work fine.
    Sep 2015
    48
    I try pecking I checked...Machines stand out 14 years (2001) :O Even all the works except of buttons.
    Sep 2015
    48
    Pecking at the button min 500 times and nothing
    Feb 2011
    640
    sorry. have seen a lot of sketchy keyboards revived by use, obviously not gonna happen with yours-
    I think john-100's print is your best bet to check out
    Dec 2015
    11
    Quote Originally Posted by Prnya View Post
    Help! Help! Help!
    I have had this problem. An operator crashed one of our lathes pretty hard. Took a bit of trouble shooting. I found one of the Honda cables was jarred loose where it hooks to the main board. Try turning the machine off then unplug and replug them. Try to find the one coming from the keyboard (MDI unit).
    Hope this helps you.
    Sep 2015
    48
    I tried to separate cables, related to the control unit around the keyboard...Whatever I do is turn on again...Nothing...I'll have to find a professional masters, I will write what happened, as soon solve the problem.I think it is a folly
    Sep 2015
    48
    Just to mention...Keys are back and all the great work.After a certain time burned the circuit under the monitor (fuse 32x6 mm 1.6A).After replacement again it happened that the keys do not work, but after a day of working again.And they seem to work when I was picking the buttons below panel (buttons light,spindle for rev stop).Maybe it was something stuck so upsetting to other keys.Generally I do not understand what happened , but time will show their...I hope that it will now work well
    Jul 2014
    6
    i have 10 t controll in fanuc..Sometimes the buttons O M I arrow key are not working...any Solution for that..Plz reply
    Sep 2015
    48
    Quote Originally Posted by aravindbabu View Post
    The problem was in the central panel that connects the keyboard plate to the back plate. One wire is solved all.Or contacts are bad or cold solder...All buttons now work
  1. Replies: 7
    Last Post: 01-10-2024, 10:14 PM
  2. Replies: 4
    Last Post: 11-03-2013, 09:46 AM
  3. Those Big Red Stopper Buttons?
    By crash5050 in forum DIY CNC Router Table Machines
    Last Post: 03-08-2010, 09:25 PM
  4. buttons going out? need help
    By DerHammer in forum Fanuc
    Last Post: 03-10-2008, 04:25 AM
  5. Fanuc OT Buttons dont work
    By flannman in forum Fanuc
    Last Post: 11-27-2007, 02:40 AM
