586,110 active members*
3,401 visitors online*
Login Register
CHIRON Group SE Forum
PERFORMANCE MEETS PRECISION
HURCO > Hurco KM3 BELT CHANGE
Results 1 to 14 of 14
    Apr 2009
    11
    Anybody done a variable speed belt change, and, bearing change on a Hurco KM3 head.
    I will put pictures up as I do it.
    First thing I did was to remove main motor at back of ram!
    .............disconnect wireing from motor box
    .............undo cap heads under motor on lower casting
    .............undo nut holding tensioner spring, carefully, lever brake on side to stop motor turning
    Wireing, note wire positions ...........
    U
    Bottom Plate x 3 cap heads........
    Lever Brake on to stop motor turning .......
    Undo nut, watch for spring?...... keeping brake on!
    Undo cap heads holding motor....... remove
    Check the Nylon Splined Bush, any excessive wear, change if possible.
    Apr 2009
    11
    Re: Hurco KM3 BELT CHANGE
    .............disconnect wireing from motor box, making a note of where they go!
    Apr 2009
    11
    Next, while holding the brake on, using a socket undo the nut holding the tension spring on.
    Obviously, undo while keeping the pressure on
    Mar 2024
    11
    I initially took the Head off before undoing the Spring, better to undo spring with Head still on as above.
    Then removed the brake solenoid using a 10mm spanner
    Mar 2024
    11
    Found this document online somewhere, it says put the spindle to max speed, unfortunately my machine was'nt working when I got it so I could'nt do that anyway.
    I have already removed the Spindle motor cover and Spindle Motor, left the belt.
    Mar 2024
    11
    Mar 2024
    11
    Mar 2024
    11
    I Have tried to put the pictures in some sort of order, but it was removed a while ago, so check as you go along.
    took a picture of the chain length to remind me how long it was, so that it goes beck the same.
    Mar 2024
    11
    I removed nut and measured it, just in case?
    Mar 2024
    11
    The Head woud'nt lift off cleanly and easily, probably because the dowels were a tight fit, I tried to use Aluminium levers but I was concerned about damaging the casting, so I opted for gentle pressure using threaded rod which allowed me to lift the head equally all round.
    Mar 2024
    11
    Heads finally off, here's a view of all the Belt numbers
    37/10/850
    40173 x 1 1/4 B9N1 (Made in UK) Powergrip
    Mar 2024
    11
    With the spindle regulating (no6 in the manual) top plate and disc/variable angled plate off, I removed the belt by sliding it over the pulley-difficult, not the right thing to do but I was'nt sure if I should undo the pulley nut as I was'nt familiar with the setup, so I opted for the obvious and easiest, and I was replacing it.
    Mar 2024
    11
    Finally off, belts in a right mess, so new belts and new bearing
    Feb 2006
    174
    Thank You MacDave 73
    Appreciate the magnificent work and pictures !
    rich
  1. Belt Change Help
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 04-12-2015, 04:51 AM
  2. A20 Citizen guide bushing belt change
    By Rittpuck in forum CNC Swiss Screw Machines
    Last Post: 11-15-2013, 05:10 AM
  3. need to change belt on hardinge vmc 1000
    By ikneb in forum Bridgeport / Hardinge Mills
    Last Post: 06-03-2013, 07:12 PM
  4. Spindle orient oi-mb after belt change
    By MidniteOil in forum Fanuc
    Last Post: 09-10-2011, 12:52 PM
  5. 6'' Craftsman lathe belt change
    By Rusty Knuckles in forum Want To Buy...Need help!
    Last Post: 02-11-2011, 02:27 PM
