My membrane keyboard on my M400S quit working. I've tried several things to get it working again without any success:
- Replaced with new membrane keyboard ($650 - ouch)
- Pulled daughter board from motherboard, cleaned connectors on daughter board and right angle adapter with scotchbrite. Examined PCI connector on motherboard. Pulled cable from daughter board to membrane keyboard and reset.
- Changed out SD hard drive with working version from a few years back
- Dug through set up parameters within Centroid. Didn't find anything to change except for ability to turn on/off membrane keyboard. Went ahead and changed, then rebooted. Still does not work.
- Noted that when booting program, lights on membrane keyboard flash, so I don't think it's a power supply problem.
- Unplugged pendant in case it had a short.
I'm not sure what to do next. It could be a problem with the daughter board, but since all other functions it performs seem to work OK, it's probably unlikely. I have been able to:
- home system
- run programs
- move the table using G-code using MDI
Other things I could do:
- Check cable from daughter board to membrane keyboard with voltmeter for breaks or shorts. It was supposedly done, but I didn't do it myself, so I don't know exactly what was done.
I'm running Centroid version 2.7 on Red Hat Linux.
Any ideas?
