588,068 active members*
5,011 visitors online*
Login Register
CIMATRON Forum
NEED HELP WITH .GPP FILE
Printable View
  • 01-30-2012, 11:21 AM
    IlFincoITA
    2 Attachment(s)
    Hi! I'm trying to edit an old .GPP file for a deckel Fp4MA. Everithing is working just fime but since this machine need that z compensation must be wrote after any z changes i've discovered a mistake. It puts the D+ code after Z changes but it does this change aven after a x or y change and i can't discover where is the problem into the .GPP file. Could someone check this .GPP file? Thanks a lot...
  • 01-30-2012, 11:37 AM
    G00Z0
    would you like to give a short example where I can see the NC code directly from the actual GPP file.
    Please mark the mistakes or how it should work correctly.
    Sorry, I didn't open the attached picture.
    I will have a look.
  • 01-30-2012, 12:41 PM
    G00Z0
    Try this:
    {[' X'xpos], [' Y'ypos], [' Z'zpos,' D+'tool_number]} <- insert here
    if save_feed <> feed or change(feed) then
    m_feed_flag = true
    endif
    if m_feed_flag eq true then
    m_feed_flag = false
    {' F',feed,' D+'tool_number} <- delete this
  • 02-02-2012, 11:48 PM
    IlFincoITA
    OK I have solved that part in this way:
    m_feed_flag = false
    {' D+'tool_number' F',feed} <== putting ' D+'tool_number just befor ' F'
    Now the problem comes here
    @move_xy
    gcode = 0
    if first_rapid_move eq true then
    {nb,'G'gcode,[' X'xpos], [' Y'ypos]}
    call @start_tool
    {' M08'}
    {nb,'G'gcode,[' Z'zpos],' D+'tool_number}
    first_rapid_move = false
    else
    {nb,'G'gcode [' X'xpos], [' Y'ypos], [' Z'zpos],' D+'tool_number} <===i've put the compensation here!
    endif
    endp
    This works but effect X and Y too... besides Z must be in a new block lonely with d+ compensation.
    Her's what I get:
    N0010 G00 X-163400 Y+22510 S+2000 M08
    N0020 G00 Z+10000 D+01 <== Good Here
    N0030 G00 Z+2000 D+01 <== Good Here
    N0040 G01 Z-25500 D+01 F500
    N0050 G02 X-152470 Y+34400 I+36400 J-22510 F1000
    N0060 G02 X-152040 Y+34600 I+730 J-980
    N0070 G01 X-143720 Y+36700
    N0080 G02 X-142910 Y+34400 I+300 J-1190
    N0090 G03 X-163400 Y+10560 I+15910 J-34400
    N0100 G00 Z+10000 D+01 <== Good Here
    N0110 G00 Y-22510 D+01 <== BAD HERE
    N0120 G00 Z+2000 D+01 <== Good Here
    N0130 G01 Z-25500 D+01 F500
    I've tryed to but D+ inside [' Z'zpos] but it mess up the things too:
    N0110 G00 Y-22510 Z+10000 D+01 <== It goes with Z but move Z into Y line
    Anyone hase a solution please... thanks a lot...
  • 02-03-2012, 09:16 AM
    G00Z0
    Quote:
    Is this the only mistake ? When "yes", you have to set a flag for the "D+01" output. Is it so ? Every sentence with single axis output in Z must have the "D+01" ?
    Try something like that:
    if ( (change(xpos) eq false) and (change(ypos) eq false) and (change(zpos) eq true) then
    {'D+',tool_number}
    endif
  • 02-03-2012, 12:07 PM
    IlFincoITA
    {'D+',tool_number}
    endif
    GREAT! IT HELPS ME THANKS A LOT
  • 02-03-2012, 12:09 PM
    IlFincoITA
  • 02-06-2012, 11:39 AM
    IlFincoITA
    Hi! It is a last thing that i don't understand...
    @call_proc
    integer_def_f = BLKNUM_F
    {nb,'L1 N*'start_line}
    {' N*'end_line}
    integer_def_f = INTEGER_DEF_F
    endp
    this suppose to repeat blocks of program.... but it doesn't work. I didn't see any repetition in my generated G code. What is activating this procedure? I've seen in .MAC file that "loop_exist = Y".
  • 02-06-2012, 01:53 PM
    G00Z0
    This section is important if you use subprograms.
    look at this lines in *.MAC:
    gen_procs = N
    gen_internal_proc = Y
  • 02-07-2012, 12:16 PM
    IlFincoITA
    Hi! I've check it out and the setting are as you wrote in .MAC file but still no L01 repetition in my G Code...
    It suppose to generate something like this:
    N0481 L01 N0081 N0401
    Is there any setting that I must flag into solidcam operation idalog boxes or general machine setting... I can't figure out what it is?
  • 02-07-2012, 01:06 PM
    G00Z0
    Do you want to get sub programs or not ?
    If not, just write
    gen_internal_proc = N
    in the *.MAC
    If "yes", why ?
  • 02-07-2012, 01:30 PM
    IlFincoITA
    Of course I want to use subprogram... the memory on FP4MA is very small... I need to short the program as much as possible.
    I mean sub program is when a piece of program is repeated inside the main program... for example a toolpath that is equal but has a different Z depth: Because what I see is that Solidcam generates the full G code repeating the complete toolpath aven wen it is the same ad the only thig different is the Z depth. That wath I need to avoid...
    You see (this is generated with gen_internal_proc = Y) :
    N0010 G00 X-129500 Y+0 S+1000 M08
    N0020 G00 Z+10000 D+05
    N0030 G00 Z+1000 D+05
    N0040 G01 Z-6000 D+05 F33
    N0050 G01 Y-5500 F100
    N0060 G03 X-129500 Y-5500 I+0 J+5500
    N0070 G01 Y+0
    N0080 G01 Z-11000 D+05 F33
    N0090 G01 Y-5500 F100
    N0100 G03 X-129500 Y-5500 I+0 J+5500
    N0110 G01 Y+0
    N0120 G01 Z-16000 D+05 F33
    N0130 G01 Y-5500 F100
    N0140 G03 X-129500 Y-5500 I+0 J+5500
    N0150 G01 Y+0
    N0160 G01 Z-21000 D+05 F33
    N0170 G01 Y-5500 F100
    N0180 G03 X-129500 Y-5500 I+0 J+5500
    N0190 G01 Y+0
    N0200 G01 Z-22000 D+05 F33
    N0210 G01 Y-5500 F100
    N0220 G03 X-129500 Y-5500 I+0 J+5500
    N0230 G01 Y+0
    N0240 G00 Z+10000 D+05
  • 02-07-2012, 02:54 PM
    G00Z0
    So is your sequence in *.MAC:
    Then in *.GPP you need the sections:
    @proc -> this calls the sub programm in main programm
    @call_proc -> start sequence from sub program
    @end_proc -> end sequence from sub program
    Where is still your problem ?
  • 02-07-2012, 05:24 PM
    IlFincoITA
    1 Attachment(s)
    In my .GPP I only find...
    @call_proc
    {' N*'end_line}
    endp
    @proc
    flag_start_job = true
    endp
    What is wrong is this
    N0110 G01 Y+0
    N0130 G01 Y-5500 F100--------------------------------->This is a repetiion
    N0140 G03 X-129500 Y-5500 I+0 J+5500----------->This is a repetition
    N0150 G01 Y+0
    N0170 G01 Y-5500 F100--------------------------------->This is a repetiion
    N0180 G03 X-129500 Y-5500 I+0 J+5500----------->This is a repetiion
    N0190 G01 Y+0
    N0210 G01 Y-5500 F100--------------------------------->This is a repetiion
    N0220 G03 X-129500 Y-5500 I+0 J+5500----------->This is a repetiion
    N0230 G01 Y+0
    Why it doesn't writhe those blocks under
    L01
    Like this
    N0201 L01 N0170 N0190
    and so on...
    See attached file...
  • 02-07-2012, 05:34 PM
    G00Z0
    I think at this point I have to see the PP.
    If you would mind, send me the *.GPP and *.MAC and I will have look.
  • 02-07-2012, 06:45 PM
    IlFincoITA
    1 Attachment(s)
    You're so kind... here it is...
  • 02-07-2012, 10:02 PM
    IlFincoITA
    I'm sorry I did a mistake... don't which file a was looking at but after a double check i found
    gen_internal_proc = Y was set to N
    Now I've chage it and everything is just fine.
    Sorry to have bother you guys out there... you have helped me a lot...
  • 02-08-2012, 08:17 AM
    G00Z0
    Everything is fine now ?
    The thread is closed ?
    Thanks for the conversation,
    Bye
  • 02-08-2012, 10:31 AM
    IlFincoITA
    I'm trying the G Code this morning... i'll confirm that everithig is OK within today...
    Thnaks a lot...
  • 02-08-2012, 10:42 AM
    IlFincoITA
    Nope there is still onothe issue. The line after L01 mess up the Z this is a simple program:
    ;SPALLA ALBERO MOTORE
    (&P01/0000)
    T07
    ; Fresa Piatta Ø14 mm.
    ; F-CONTOUR7 - PROFILE
    N0010 G00 X-129500 Y+0 S+1250 M08
    N0020 G00 Z+10000 D+07
    N0030 G00 Z+2000 D+07
    N0040 G01 Z-7000 D+07 F500
    N0050 L01 N0180 N0220
    N0060 G01 X-129500 Y+0 Z-14000 D+07 F500 ========>Z must go into a separate block
    N0070 L01 N0180 N0220
    N0080 G01 X-129500 Y+0 Z-18500 D+07 F500========>Z must go into a separate block
    N0090 L01 N0180 N0220
    N0100 G01 X-129500 Y+0 Z-19000 D+07 F500========>Z must go into a separate block
    N0110 L01 N0180 N0220
    N0120 G00 X-129500 Y+0 Z-19000========>Z must go into a separate block ==>Where is Dz Compensation?
    N0130 L01 N0230 N0270
    N0140 G00 X-129500 Y+0 Z+10000========>Z must go into a separate block==>Where is Dz Compensation?
    N0150 M09
    N0160 G00 Z+150000 D+07
    N0170 M30
    N0180 F750
    N0190 G41 D+57 G47 A+1000 X-129500 Y-17000 G01 G60 M61
    N0200 G03 X-129500 Y-17000 I+0 J+17000 F750
    N0210 G40 D+57 G47 A+1000
    N0220 G01 Y+0
    N0230 F750
    N0240 G41 D+57 G47 A+1000 X-129500 Y-17500 G01 G60 M61
    N0250 G03 X-129500 Y-17500 I+0 J+17500
    N0260 G40 D+57 G47 A+1000
    N0270 G01 Y+0
    0000
