588,130 active members*
4,981 visitors online*
Login Register
CIMATRON Forum
SolidCAM for SolidWorks and SolidCAM for Inventor > NEED HELP WITH .GPP FILE
Results 1 to 20 of 20
    Oct 2007
    38
    Hi! I'm trying to edit an old .GPP file for a deckel Fp4MA. Everithing is working just fime but since this machine need that z compensation must be wrote after any z changes i've discovered a mistake. It puts the D+ code after Z changes but it does this change aven after a x or y change and i can't discover where is the problem into the .GPP file. Could someone check this .GPP file? Thanks a lot...
    Attached Files Attached Files
