586,111 active members*
3,543 visitors online*
Login Register
CIMATRON Forum
T-Slot CNC building > Looking for opinions on 6040 size T-SLot Build
Results 1 to 2 of 2
    Jan 2007
    626
    Just looking for some opinions on the required thickness of the side rails need to be on a machine with a 6040 sized bed, but using longer rails.
    Have decided on 45 sized extrusions due the convenience of mount bearing blocks, etc.
    Will probably use 90mm high side rails and 45mm thick bed frame with solid 16mm thick Ali bed bolted to it.
    My heart say I should use 90 x 90mm for the side rails but I wonder if the 90 x 45's would be ok to use ( just to save money ).
    I've no experience with using T Slot.
    Will use Minitec or Bosch Nexroth extrusions....HD if I can get it.
    If its a gamble to use 45mm wide for the main rails, I won't bother.
    Steve
Name:	45 vs 90.JPG
    Jun 2020
    Re: Looking for opinions on 6040 size T-SLot Build
    @Sterob@happy wheelsI think: Use 90mm high side rails and 45mm thick bed frame with solid 16mm thick Ali bed bolted to it.
  1. T-Slot 'only' CNC Design, opinions needed
    By saslanis in forum T-Slot CNC building
    Last Post: 02-23-2019, 08:50 PM
  2. TSlot size for 6040
    By petethered in forum Chinese Machines
    Last Post: 11-09-2015, 10:47 PM
  3. What size steppers come with 6040?
    By storm2313 in forum Chinese Machines
    Last Post: 01-02-2013, 01:56 PM
  4. HRT 210 T slot size ?
    By mishikwest in forum Haas Mills
    Last Post: 05-07-2010, 07:37 AM
