586,103 active members*
3,697 visitors online*
Login Register
CIMATRON Forum
PlanetCNC > [TNGv2] - Machine 3D visualization
Results 1 to 18 of 18
    Mar 2017
    1312
    Your machine 3D visualization is possible since version 20020-03-24.
    Machine 3D definition is made with 3dObj.txt file. Samples folder contain profile from which image above is taken.
    It is possible to use simple objects like cuboid, cylinder, sphere or STL files.
    Mar 2017
    1312
    Re: [TNGv2] - Machine 3D visualization
    I got several question how to make this work.
    Everything is in 3dObj.txt file. This is actually xml file with machine definition. If you copy this file to your profile folder you will see machine like in screenshots above.
    And make sure you have menu option "View/Show/Objects" checked.
    We plan to make better tutorial for this. It is also possible to use stl files of your actual machine.
    Until then, ask questions here and please share, what you learned and made with others.
    May 2008
    266
    I've just tried the sample machine (router) simulation and although I have a lathe, it still delivers a great representation of the movement and relative position of cutter/machine/workpiece. Very useful indeed.
    I could easily create STL files of my machine, but how would I integrate them into the 3dObj.txt file?
    For now I'll play with a copy of the original 3dObj.txt file and see if I can edit out a few irrelevant objects and alter what is left.
    Thanks for this.
    Mar 2017
    1312
    Here is an example for STL files.
    May 2008
    266
    Managed to make some progress with my lathe but I need to experiment more with how to get the saddle & cross slide to stay together as a unit as they move (see second & third pic), as the workpiece is always in the same position relative to the spindle which is a bit different to a milling machine.
    Good fun though!
    Attachment 439348
    Attachment 439350
    Aug 2011
    252
    Nice feature, but I am dumb and understand nothing just by looking at examples.
    Any chance for a tutorial?
    Jan 2022
    107
    Is there a way to hide/show parts of the 3D Visualization or change their parameters from script?
    Would be nice to show the state of the ATC by hiding the tool in the ATC when it is the current tool and instead show the tool at the spindle location.
    May 2022
    3
    What are you doing to the 3d file to make different parts of the 3d render in PCNC different colors? I can get a .STL to upload in the software where i want it but its all gray. would be cool to change up some of the colors like in the screenshots you posted.
    Jan 2022
    107
    just add
    <Color Value="ffffffff"/>
    to the desired part.
    the value is in hex RGBA notation.
    Mar 2017
    1312
    3D visualization is completely redesigned.
    Now all machine types can be visualized in motion.
    https://www.youtube.com/watch?v=sP70xxPt5JU
    Mar 2017
    1312
    Here is another one.
    This one shows rotary 4th axis.
    https://www.youtube.com/watch?v=YOVL2kvD7Ys
    Mar 2017
    1312
    Rotary 5th axis visualization
    https://youtu.be/3c-d-VeyuJY
    Is there any update for this? I tried copy/pasting the 3dObj.txt file into my Profiles folder and it didn't change anything. Tried pasting it into the Profiles/Default folder and no change either. I then tried the 5AX files as well (with the STL files inside the 3dObj folder and outside it as well.) I changed the filename in the Settings -> 3D -> Model text field as well. Still no go.
    View -> Show -> Objects does not exist. I only see Position, Viewspace, Model and Toolpath History in the View -> Show menu.
    Even a screenshot of the folder/file structure in the Profiles folder and a screenshot of the Settings screen would be helpful.
    Jul 2023
    3
    I would also like to use the machine visualization feature but it doesn't appear to exist in the newest version. When will this be available?
    Jan 2022
    107
    Maybe I can point you into the right direction by sharing my Profile which includes working 3d visualization.
    https://github.com/styletronix/PlanetCNC_CNC1
    That brings me to a question... I have now set the option to show and hide individual objects in the visualization. For example, the Tools in the Tool Changer are now shown and hidden to reflect the actual state. But as mentioned somewhere, it only updates the object visibility if I hide and enable the 3d view.
    A command who can be triggered from expressions or gcode, which refreshes the display would be very helpful.
    Mar 2017
    1312
    You can use expression:
    cmd("View.Show.Model");
    (twice, first time to hide, second time to show).
    I will add optional arguments so that calling command twice will not be necessary.
    Jan 2022
    107
    Ahhh, that sounds really nice. I have implemented it right now. You can give it a try on this link https://github.com/styletronix/PlanetCNC_CNC1
    First do Homing procedure and then you can change the tools and use the "Niederhalter". That's one of the Buttons on the top right. That is so cool. I have many details which I can implement now.
    Mar 2017
    1312
    Here is a tutorial on 3D visualization. This tutorial will be added additional info in the future:
    https://cnc.zone/kb/tutorials/expert...n_tng_software
  1. TNGv2 Machine Limit Reached
    By theRat in forum PlanetCNC
    Last Post: 11-17-2019, 05:06 PM
  2. [TNGv2 - API]
    By PlanetCNC in forum PlanetCNC
    Last Post: 10-27-2019, 11:23 PM
  3. NX Toolpath Visualization Time Study
    By mongo46538 in forum UG NX
    Last Post: 09-09-2009, 03:06 PM
  4. Visualization of 5-axis machining in EMC2
    By samco in forum LinuxCNC (formerly EMC2)
    Last Post: 12-21-2007, 02:41 PM
  5. g-code path visualization ...
    By deadalvs in forum European Club House
    Last Post: 05-10-2007, 10:43 PM
