586,269 active members*
3,658 visitors online*
Login Register
CIMATRON Forum
Mastercam > Mastercam 9.1 windows xp hasp not found.
Results 1 to 8 of 8
    Jan 2011
    10
    Hi, trying to upgrade my desktop and brought a lenovo Thinkcentre with windows xp professional x64 edition version 2003 service pack 2 and the problem ta I have is that after installing all drivers and software of mastercam 9.1 the computer doesn't detect tha hasp key, the hasp key turn on the red light but when open the mastercam mill give me the message " hasp not found" any help it's appreciated, thanks.
    Dec 2003
    1228
    Re: Mastercam 9.1 windows xp hasp not found.
    I recently had a similar problem with my Dell laptop on a Zoom call,where it wouldn't detect the webcam.So I attached the webcam to a different usb port and it worked perfectly.So my suggestion is to try a different port and if that doesn't work,look in device manager and see if anything jumps out as a problem.I like Mastercam 9.1 and can understand why you still use it.My other thought is that it might not be compatible with a 64 bit system and if the checks I suggested don't yield success,you may have to find a 32 bit operating system.I remember a few years ago a man I knew bought an used AXYZ cnc of some vintage and was firmly advised not to introduce any operating system newer than 32 bit XP.The information here may help https://learn.microsoft.com/en-us/tr...-64-bit-system .Obviously,a poor usb socket connection would be the least troublesome thing to overcome.Good luck.
    Dec 2008
    3110
    Check the system requirements....
    When v9.1 was available (around 2005), PCs were 32bit.... 64bit was not just comming in.
    It was a DOS app, never designed for modern operating systems
    Not sure.... but try setting the desktop icon to run in administrator mode in a 32bit environment. I may be well off the mark.
    It's a long time ago, the grey matter is getting holes... I think... where am I again.
    Jul 2023
    7
    we had the same issue, ,,,send me a message and ill explain what we did,,,
    Jan 2011
    10
    Quote Originally Posted by gREENChickend View Post
    Thanks for your response, the issue is being resolved have the computer up and running.
    Jul 2023
    7
    Jan 2024
    Have you tried reinstalling the drivers and software for Mastercam 9.1? Sometimes a fresh installation can fix things. Also, make sure you have the latest driver updates for your Hasp key. If that doesn't work, here's a little trick you can try: 1. Unplug the Hasp key from your computer. 2. Restart your computer. 3. Plug the Hasp key back in. 4. Check if the red light on the Hasp key turns on. 5. Open Mastercam Mill and see if the "Hasp not found" message is still there. If you're still having trouble, it could be because Mastercam 9.1 isn't fully compatible with newer versions of Windows.
    Jan 2024
    Quote Originally Posted by CherryG0d View Post
    You might want to consider upgrading to a more recent operating system like Windows 10 or even Windows 11, if your computer meets the requirements. Just get a windows 11 cheap key to get the current OS version.
  1. Replies: 0
    Last Post: 10-14-2013, 08:55 PM
  2. Mastercam hasp not found in Cimco Edit
    By shane.mccook in forum Mastercam
    Last Post: 09-24-2013, 09:28 PM
  3. PROBLEM: HASP NOT FOUND..MC9..Win7
    By gogego in forum Mastercam
    Last Post: 07-13-2012, 01:59 PM
  4. HASP not found error
    By AlexBanich in forum Mastercam
    Last Post: 04-27-2008, 02:14 PM
  5. HASP not found !!!
    By craftech in forum Mastercam
    Last Post: 01-20-2005, 07:25 AM
