HI
G42 and G02 cutter compensation
using 2024.01.02
I've used tool compensation on other machines, but this planet cnc controller does not seem to work the way I expect.
A simple example : tools are set up under menu tools. tool size in sim is correct.
M61 Q1 (select tool 1 with 1.5mm diameter))
G01 X0 Y2.5 (move to arc edge start )
G01 Z-1 F100 (tool down to material)
G42 (activate compensation for the selected tool, a 1.5mm cutter)
G02 X0 Y2.5 I0 J-2.5 F250 (execute arc 360 degrees a hole 5mm in diameter)
The tool goes to the arc edge (arc start) , and doesnt move in XY until it goes to the next toolpath in the program. arc gets stuck. the X and Y readouts in the sim do not change.
I tried putting the G42 ahead of the lead in move
IE:
no difference
if I change G02 to G03 and try G41 (so going the other direction, same problem.
if I use G42 P1.0 etc (direct diameter assignment) - no difference.
If I try a left side compensation G41 P0.5 that does work- but the compensation is on the wrong side of the line.
I tried using negative values with G41, that doesnt work....
any help would be appreciated.
