586,096 active members*
3,762 visitors online*
Login Register
CIMATRON Forum
PlanetCNC > Display gcode filename
Results 1 to 3 of 3
    Nov 2014
    20
    Hi.
    I would like to ask for help with displaying the file name in PlanetCNC. I'm using PlanetCNC on vertically oriented monitor and gcode filename is only partially showed in the upper bar. Just the end of the filename to be specific. Please look at the attached screenshot. It become problematic when milling boxes and faces with just small differences in their filenames.
    I tried displaying the file name on bottom tab next of step buttons, using param function, but it looks like there is no expression for file name.
    Someone solved this?
    Thanks.
    Mar 2017
    1312
    Re: Display gcode filename
    Parameters for this will be in next version.
    Nov 2014
    20
    Great news. Thank you very much
  1. Programming a Display Program for GCode
    By JANAVISHAH in forum G-Code Programing
    Last Post: 08-15-2019, 10:32 AM
  2. Programming a Display Program for GCode
    By ZSamuels28 in forum G-Code Programing
    Last Post: 07-12-2011, 02:00 AM
  3. Upload Program with Filename
    By Smrtman5 in forum Haas Mills
    Last Post: 12-21-2010, 02:11 AM
  4. Newbie Q: (Mach/Gcode/Tormach?) display vars?
    By rc33 in forum Tormach Personal CNC Mill
    Last Post: 11-18-2008, 10:16 PM
