TK,
I decided to rebuild my dedicated XP computer that uses the KFLOP / KANALOG cards to control motion. To be able to take advantage of the Screen Editor feature available in later releases I decided to get Windows7 and a new hard disk. I did not like all the bloatware that Microsoft put on Windows8 and Windows10, since this computer is only used for the CNC machine.
The first thing I did was install Windows7 and got all the updates a four hour exercise, but all updates installed perfect and the computer works just fine.
The next thing I did was to install Kmotion 4.34H on the computer which was in my office, not in the garage with the CNC machine. After the software was installed I copied my c programs from the old install saved on a flash drive to the C program folder. These programs were all slightly modified so I had their names different that what I list below.
1) HomeMM_V7.c
2) InitStepDir3Axis.c
3) MPG-InitStepDir3Axis.c
4) SpindleMach3DAC.c
Then I went down to Kmotion434h/Kmotion/Data
I copied some of the .TXT files
Config.txt
GCodeConfig.txt
Threads.txt
Gviewer.txt
There are others I saved but I don't think I touched those not positive, need guidance since I could not find a guide on exactly how to do this type upgrade.
The software installed fine but when I started it it complained there were no USB drivers. I realized since I did not have the KFLOP plugged in the USB drivers never got installed. I went into control panel/device driver and pointed it to the Kmotion434h/USB Driver folder and the drivers installed in a few minutes.
Now I can start Kmotion and get no errors, but before I go on I believe I need to flash the unit. It warns me I will lose everything so I am checking to make sure I have everything done.
I think after I flash the unit, with the Kmotion 434h firmware, that I need to compile the C programs and download them into the KFLOP. Then I should be ready to go?
Have I forgot anything? Thanks
Russ
