586,102 active members*
2,664 visitors online*
Login Register
DMG MORI Forum
Hyundai Kia > Kia KT15. 310 alarm
Results 1 to 2 of 2
    Feb 2016
    115
    Kia KT15. 310 alarm
    I just bought a Kia KT15 turning center and when I power it up it shows a 310 alarm something servos not on, has anyone else had this problem and what had to be done to fix it?
    Feb 2016
    115
    Re: Kia KT15. 310 alarm
    I got my Kia KT15 turning center fixed!
    It was throwing a 310 servo off alarm
    The problem was a bad overload not a tripped overload a bad overload! You could reset it to be NC and the contacts inside weren't making contact, first I bypassed it and hooked the wires together and the 310 alarm went away and the lathe powered up and worked great! So I powered it down and removed the overload and took it apart and cleaned the points in it and got it functioning properly and making contact reinstalled it hooked the wires up and the lathe works great now! So if you're having problems don't just check to see if the overloads are tripped check them with a meter and make sure they're working properly!
  1. Kia KT15 manuals?
    By Redzilla in forum Hyundai Kia
    Last Post: 11-05-2023, 03:11 AM
  2. Hyundai Kia SKT 100 turret amp alarm AL 62 (Alarm 2062)
    By roboticist in forum Hyundai Kia
    Last Post: 02-16-2022, 06:01 AM
  3. Need help, kt15 clearing alarm codes
    By panaceabeachbum in forum Hyundai Kia
    Last Post: 01-06-2014, 08:03 PM
  4. KIA KT15 cnc lathe
    By diemech in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-04-2011, 04:54 AM
  5. How to home KT15 alarm 280?
    By panaceabea in forum Hyundai Kia
    Last Post: 01-22-2010, 10:45 PM
