586,112 active members*
3,068 visitors online*
Login Register
DMG MORI Forum
For Sale Only > 5 AXIS DOUGHTY DRIVE + CNC4PC CONTROL BOX & CNC TABLE PARTS/EQUIPMENT FOR SALE!!
    Jul 2014
    Hi All,
    I'm based in Melbourne, Australia and have for sale an unused / brand new condition 5 Axis Doughty Drive and many other parts, accessories and equipment (all in brand new/open box condition) which was procured with the intention of building a 1220mm x 2440mm CNC router table. Unfortunately I wasn't able to complete the build and all components have been stored in original packaging in my spare bedroom cupboard (a perfectly clean and dry environment).
    Please refer to the attached zip folders which contain photos of the Doughty Drive and associated equipment/parts for sale.
    While this CNC router table was custom designed by Colin Doughty for the increased cutting table area of 1220mm x 2440mm, the Doughty Drive system can be adapted for any sized CNC router table or mill project to suit your needs. All the original build plans, manual & technical correspondence can be provided.
    Essentially, all the equipment and components needed for a fully operational 5 axis CNC router table was procured except for the maytec aluminium table/gantry frame sections and the main lead screw needed for horizontal movement of the gantry across the length of the table and also some electrical parts such as junction boxes and incidentals to complete the wiring/cabling (although most cabling will be provided).
    A breakdown of the major components FOR SALE are as follows (all values in $USD and exclude shipping costs):
    *Estimate Shipping Cost to USA: refer item no. 1 below
    • The Original Doughty Drive Manual (comprehensive instructions including detailed assembly diagrams, dimensions of machined parts and potential suppliers).
    Original purchase price: $150. Sale Price: Free of charge and included with purchase of Doughty Drive Head Unit.
    • The new adapted design and detailed plans to suit the increased table size of 1220mm x 2440mm. Can be made available upon request as part of the Doughty Drive Head Unit purchase although have provided some 3D design images in the attached zip folder to wet your appetite.
    • CNC4PC CNC Control Box including Stepper Motors, Motion Controllers, Spindle etc, inclusive of the following (refer to manual included in attached zip folder):
    - 5 axis system,
    - Ethernet connectivity with PC, using the Ethernet Smooth Stepper,
    - Based on C32,
    - 6 x G203V Drivers,
    - 2 x RHT34-740 + 2 x RHT34-980 motors,
    - Connectors for pendant, probe, limits/homes,
    - MPG12 6 Axis Pendant,
    - A61 Inductive Switch Assembly to RJ45,
    - Touch and Tool Probe w ¼ shaft,
    - One AC relay controlled plug,
    - 65VDC@20A Power Supply / 220VAC single phase (note that Australian domestic power plug has been fitted which may need to be changed to a different plug type to suit your local power requirements). Power supply wiring may also need to be adjusted to suit local requirements (wire diagram is provided in the attached zip folder fyi).
    - 2hp Spindle +1.5Kw VFD inverter & 3 x ER20 collets (would prefer not to sell the spindle separately as it’s VFD/inverter has been incorporated into the CNC4PC Control box build, hence part of this package, h/ever may consider separate sale price of around $400USD if offers are received),
    - Control Box Enclosure 642, 600x400x250
    Original purchase price: $5,200 (incl. spindle & inverter). Sale Price: $3,200USD.
    *Estimate Shipping Cost to USA: refer item no’s. 2, 3 & 4 below
    • Miscellaneous Parts & Accessories required to build the Doughty Drive CNC table system as per the amended Doughty Drive design for table size of 1220mm x 2440mm, inclusive only of the following:
    - Custom machined aluminium plates for assembly of the Doughty Drive supplied by local aluminium engineering machinist,
    - Martin spur gears (3no.) supplied by ‘Martin’,
    - Gear racks and rack clamps (to suit 1220mm x 2440mm table size) supplied by ‘CNC Router Parts LLC’,
    - Timing belts and pulleys supplied by ‘QTC Econobelts’,
    - *I still have the 64bit ASUS Windows 8 laptop running Rhino 5, Madcam plugin and Mach3 (note Rhino & Madcam are perpetual student licenses as I was a student at the time and Mach3 is a standard perpetual license). If this is of interest please let me know, however I would recommend that the latest versions of the software programs be purchased and be installed on a new pc - DYOR!!.
    Original purchase price: $2,900USD. Sale Price: These miscellaneous items will be included FREE OF CHARGE (excluding shipping costs – refer below) if the Doughty Drive + CNC4PC Control Box & Stepper Motors Package is purchased (ie. $2,700 + $3,200 = Package Deal Total of $5,900USD).
    *Estimate Shipping Cost to USA for MISC Parts & Accessories: refer item no’s. 5, 6, 7 & 8 below. Note that it may be cheaper to procure the QTC parts (box no. 7) locally however I will try to squeeze these items in boxes 1, 2 and 3 if package deal is purchased to reduce shipping costs.
    I would prefer to sell the entire Package Deal of $5,900USD to someone (consisting of 8no. packaged boxes of various sizes), but will consider individual offers for the Doughty Drive only at $2,700USD or the CNC4PC Control Box (including Motors & Spindle) only, at $3,200USD, or other offers for individual components.
    Please get in touch with any questions/offers here on cnczone, or direct to [email protected].
    PLEASE ALSO NOTE THE FOLLOWING shipping cost estimate (in AUSTRALIAN DOLLARS $AUD) for delivery to the United States (shipping costs to other locations TBC) for each of the 9no. packaged boxes:
    Estimate Shipping Costs to USA (these costs exclude customs charges as applicable in destination country):
    1. Doughty Drive: $225AUD
    2. CNC4PC Control Box: $455AUD
    3. Stepper Motors, Pendant, Probe, Cabling: $330AUD
    4. Spindle: $185AUD
    5. Aluminium Plates Box 1: $125AUD
    6. Aluminium Plates Box 2: $170AUD
    7. Misc Parts (Timing Belts & Pulleys): $155AUD
    8. Gear Racks: $225AUD
    *note that there could be an opportunity to combine the aluminium plates from boxes 5 & 6 and Misc Parts from box 7 into a single box, or incorporate into boxes 2 or 3 to reduce shipping costs if the Package Deal is purchased. And if you are interested in purchasing, and not from the USA, just let me know location country and will recalculate shipping accordingly.
    And finally, I’d also like to state in advance that any interested purchaser should be made aware that the build process is a challenging one for those who do not have prior experience with, or at least a keen technically minded appreciation of electrical/mechanical engineering systems. And for those who are novice but still tempted to dive into the world of CNC, be prepared for a bit of hard work to complete the assembly as this is not a plug and play system, however, when you do persevere and complete the build then you shall be rewarded with an absolute bargain CNC table with incredible capability (DYOR: most other 5 axis cnc router tables are around the $100K USD mark – the Doughty Drive system is an incredibly economical solution by comparison, particularly for a 1220 x 2440 table size).
    Cheers all and thank you for reading!!
    DCB
    Jul 2014
    Re: 5 AXIS DOUGHTY DRIVE + CNC4PC CONTROL BOX & CNC TABLE PARTS/EQUIPMENT FOR SALE!!
    Hi All,
    Just updating my ad above; have sold the Doughty Drive and spindle.
    At this stage will hold onto the remainder of the gear incl cnc control box, stepper motors etc in case I catch a second wind and decide to finish the build one of these days!
    In the meantime feel free to reach out if interested in any of the other gear listed is of interest.
    Many thanks
    DCB
  1. Replies: 0
    Last Post: 10-15-2020, 11:01 PM
  2. 5 Axis doughty drive for sale
    By kodie100 in forum For Sale Only
    Last Post: 02-07-2018, 07:49 AM
  3. Xylotex 4 axis control box for sale.
    By hacker7 in forum Xylotex
    Last Post: 10-01-2014, 05:48 AM
  4. CNC4PC cnc control box anybody uses them?
    By rockingchris in forum DIY CNC Router Table Machines
    Last Post: 12-24-2012, 06:51 PM
  5. B+C Axis Head (Doughty Drive) For Sale ?
    By Schweinhund227 in forum Canadian Club House
    Last Post: 08-14-2010, 01:32 AM
