587,792 active members*
3,444 visitors online*
Login Register
EMUGE-FRANKEN Forum
Fanuc > 4072 Chill flow alarm
    Feb 2023
    5
    Question 4072 Chill flow alarm
    Hi. Im operating an Amada Alpha III laser and the control is displaying a chill flow alarm after changing the filter, cleaning the strainer, and making sure the water levels were good any tips?
    Jan 2013
    474
    Quote Originally Posted by msaunders99 View Post
    Could be an air lock, try bleeding the air or priming the pump.
    Feb 2023
    5
    Re: 4072 Chill flow alarm
    it seemed that the impeller in the digital flow switch got jammed with something and wasn't spinning. after reassembling it the alarm cleared
    Jan 2013
    474
    Probably a bit of debris from your service work of the system. Sometimes components fur up when exposed to atmosphere too.
