587,564 active members*
3,266 visitors online*
Login Register
EMUGE-FRANKEN Forum
WoodWorking Topics > help
Thread: help
Results 1 to 3 of 3
    Sep 2023
    help
    Hi, guy, iam new here and also in cnc just begginer.. sorry for stupid question.. but if anyone can help me I will be thanksfull.. in which topic I can find help about what kind of router bits and settings of router bits do I have to use for engraving 3D files? like for example as in attachement here.. many thx for answer and have a nice day
    Apr 2004
    5749
    Re: help
    I couldn't see your first file, but the second one isn't an engraving but a 3D relief. To carve something like that, I'd suggest using as large a ball-nose endmill as your router can handle to do a roughing pass that gets most of the wood out of the way, and then following up with a finish pass using another one with a ball-end tip that can get into the smallest details. I like tapered ball-nose bits for this sort of thing, since they're more robust than an endmill (or router bit) that has that small a diameter all the way up its length of cut.
    Andrew Werby
    Website
    Jun 2005
    1730
    Re: help
    To carve a 3D image like you posted you will need various bit several different size ball endmills from 1/4” down to1/16” and some roughing endmills like 1/4” down to 1/8” straight endmills. Some Cam software like carve pro or Aspire to generate the gcode
