587,945 active members*
3,438 visitors online*
Login Register
EMUGE-FRANKEN Forum
HURCO > Need help z-axis encoder
Results 1 to 7 of 7
    Dec 2006
    13
    Need help/advice from experienced members of the group, about the Yaskawa feed back unit model: TFUE-25ZD7. The coded disc of this unit has been broken during transportation of HUCRO BMC10 machining center. Please guide from where I can get the disc or encoder. If some body can help giving me the specification of encoder. Is there any compatible unit or disc available in the market? Want to save $$. Thanks
    Mar 2007
    29
    Best place to check is Ebay "around the world." Meaning all the Ebay's, in US, Canada, UK, etc. That's where I found an encoder for my Hurco when I needed one. Same thing happened to by disc, it was broken along shipping.
    Dec 2006
    13
    need help Z-axis
    There is one available at Ebay, asking $ 999.00, which I thing to much for an old used encoder, on the other side Yaskawa offering a new one for $ 1150-00. This an old model only positing encoder, can I use any any encoder instead of paying for much, I am looking for the specification of this encoder. What you suggest for any other encoder of same voltage and PPM, any technical help? Thanks for responding.
    24220
    If you are sure it is positioning only, does not have commutation tracks on it if AC servo, then you should be able to sub it if you know the pulse resolution, and it is incremental and not an absolute encoder.
    if it is hollow shaft mount, then their are manuf. like Hengstler or Renco can probabally match it up.
    Al.
    Albert E.
    Dec 2006
    13
    need help Z-axis
    This encoder is only for positioning only, old model for DC servo, incremental, not a hallow shaft one, I do not know the PPM. I have requested the manufacturer for details. I only know +5 volt., with Dc generator. Please advice from where I can get the technical details of YASKAWA TFUE-25ZD7 and what will be best alternative of this.
    24220
    If remove the encoder and open it up and inspect the glass scale, the resolution in p/rev is sometimes etched near the centre hub.
    This may be worth a try.
    Did you also try Yaskawa support?
    Al.
    Albert E.
    Dec 2006
    13
    need help Z-axis
    Thanks! I will try to read the disc.,and let you know, on the other hand have tried to contact YASKWA for specification no reply. Can you suggest any information zone for Yaskawa?
  1. Replies: 40
    Last Post: 02-08-2008, 12:03 AM
  2. reinstalling x axis servo and encoder
    By fcycles in forum Milltronics
    Last Post: 12-11-2007, 07:30 PM
  3. Z axis encoder
    By bbrreid in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2007, 12:16 AM
  4. Replies: 0
    Last Post: 07-22-2005, 09:51 AM
  5. No Encoder Counts On X Axis. Y=OK
    By murphy625 in forum CamSoft Products
    Last Post: 03-09-2005, 03:20 AM
