586,112 active members*
3,111 visitors online*
Login Register
EMUGE-FRANKEN Forum
RFQ (Request for Quote) > Simple CNC Milling - Mild Steel
    Feb 2011
    15
    These parts are going to be used as tools to hold parts in a vice, so any mild steel will suffice. All tolerances are +/-.005 except for the outermost 4.000 and 2.000 dimensions, those are +.25/-0.
    I only need one of each part and I am on a tight budget and time-line so this job would probably be best for a home machinist or small business that can get these parts to me in a week or less for a reasonable price.
    Thank You,
    -Eric
    Attached Files Attached Files
    Feb 2011
    15
    Forgot to post my email address:
    [email protected]
    Feb 2011
    15
    I'd also like to add that the inside corners DON'T have to be squared, a radius is allowed. I realize it is easier to machine this way, I just completely forgot to draw that in there.
    Nov 2007
    60
    quoted
    PM sent!
  1. 1" mild steel milling
    By LarryRichardson in forum Employment Opportunity
    Last Post: 09-29-2010, 01:31 PM
  2. Any one ever built a milling machine for cutting mild steel? Any builds on here?
    By Apples in forum Uncategorised MetalWorking Machines
    Last Post: 08-19-2010, 05:31 PM
  3. Mild Steel
    By MBG in forum MetalWork Discussion
    Last Post: 03-09-2007, 11:20 PM
  4. RFQ: Milling needed in mild steel.
    By SCCoupe in forum Employment Opportunity
    Last Post: 12-11-2006, 03:06 AM
  5. A Mill for milling HSLA and Mild Steel
    By deep_drill in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2005, 05:29 AM
